Inspect and clean your disc Take a close look at the
bottom side of your game, movie, or music disc (the side without a label or
image). Are there scratches? Excessive scratches or smudges can prevent your
console from reading the disc. Clean your disc Hold the disc
by the edges without touching the top or bottom surfaces. Using a soft,
clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to
clean the disc.
Once the disc is clean, load the disc into your
console and see if the disc plays.
Or Click here to download repair guide
Clean your disc Hold the disc by the edges
without touching the top or bottom surfaces. Using a soft, clean, slightly
clean the disc.
console from reading the disc. Clean your disc Hold the disc by
clean the disc.
· Note Use
ONLY water to clean the disc.
· Once
the disc is clean, load the disc into your console and see if the disc plays.
image). Are there scratches? Excessive scratches or smudges can prevent your console
from reading the disc. Clean your disc Hold the disc by the
edges without touching the top or bottom surfaces. Using a soft, clean,
· Note Use
· Once the disc is clean, load the disc into your console and see if the disc plays.
To solve this open tray problem
from reading the disc. Clean your disc.....
· Note Use
Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
Please elaborate! what have you done so faf?
