I don't have the original manufactures remote control, and the universal controller that I purchased from Radio Shack worked for a while, but no longer works on the T.V. I need to access the menu feature in order to watch movies or play games on the set. What other options can I follow to gain access to menu.
SOURCE: Toshiba televisoion problem
there should be a control on the set at the panel to switch this over to video. Might be in a door area or right up front if not U will to obtain a remote
SOURCE: How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
SOURCE: My remote will not work
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
SOURCE: I have a Toshiba 24af42 with no remote.
Try this website 1-800-remotes Factory original u can buy an original remote,tries Channels up or down couple times u should get in the input 1 or 2.
SOURCE: My remote control on my toshiba 32
A lot of times it is the remote sensor in the set. These are good sets so I would have it checked out. Could be fairly cheap. Thanks for using fixya.
