20 Most Recent Toshiba 24AF45 24" TV Questions & Answers
0answers
manual
I need the universal remote code for my tv with an ONN ONA12AVO58 universal remote
These are the codes to check. 1075 1210 1201 1032 1140 11901195 109. If you wish to get more http://electrohelponline.blogspot.com/ check this link. Pull up older posts there, either by its left side bar, or see it in Timslide option.
6/25/2013 10:21:21 AM • Toshiba 24AF45... • Answered on Jun 25, 2013
24af45 from top to bottom picture is wavy until set warms up
Check and replace all the electrolytic capacitors at its vertical scan output stage circuit. Replace all of the once.
4/4/2013 2:50:40 PM • Toshiba 24AF45... • Answered on Apr 04, 2013
Toshiba 24af45 horizontal
If rolling in a right to left and not up down it is a sync problem--horizontal sync comes from one of two places in general---a pulse off the high voltage transformer or directly off of what is called in the trade the Jungle IC.That is not a joke--Most of these sets use a large IC (63 pins or more not unusual) that contains: color, video, vertical drive, ABL and much more---so much is crammed into that chip it decades ago was named the Jungle for clear reasons.A schematic and or scope may be needed to trace and find what is bad.if off the high voltage transformer (more common in old sets than new ones) it will be a open resistor.If at the jungle you would have to go to the pin with the sync and follow it out to see if none at source or if lost somewhere down the stream.
5/29/2012 1:31:36 PM • Toshiba 24AF45... • Answered on May 29, 2012
0answers
3answers
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
10/20/2009 7:12:04 PM • Toshiba 24AF45... • Answered on Oct 20, 2009
I got this TV from my friend and it didnt come with a remote
Well try this plug it in and flip the channels until you see VIDEO/AUX if the dont work i suggest you buy a universal remote for it.. good luck Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
4/22/2009 7:24:24 AM • Toshiba 24AF45... • Answered on Apr 22, 2009
Tv dont turn on
Yes, there was a power surge, most likely. Use a surge protector or battery backup nex time. The thing's trash.
3/16/2008 10:29:16 PM • Toshiba 24AF45... • Answered on Mar 16, 2008
Toshiba 24" TV Problem
Neither adjustable nor the picture going bad.
But appears to be a minor problem,  chances are that a component in the vertical section of the TV is starting to fail.  If you would opt to check it out/fix yourself, most probably would be a capacitor very near the vertical IC, value would be something like 100uF/50V.  Though considered a simple job, this would require that you be familiar with electronic components & circuitry, a bit of soldering and use of a DVM.
Should you not be comfortable doing the above, perhaps your best bet would be to seek the services of a qualified tech.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
10/30/2007 9:35:12 PM • Toshiba 24AF45... • Answered on Oct 30, 2007
2answers
Audio in spanish when spanish is broadcasted
consult your service manual it has all the informaton you want.goodluck.f you do not have a service manual check with www.partstore.com
8/28/2007 11:50:45 PM • Toshiba 24AF45... • Answered on Aug 28, 2007
2answers
Remote control problem
have your set checked by a repair man this is a chip problem could be the eprom.good luck.
3/23/2007 11:42:26 PM • Toshiba 24AF45... • Answered on Mar 23, 2007
My toshiba combi wont stay tuned in to tv to record tv programes why?
Tuning drift is the fault. you should check all the system control voltages to locate the fault. It is a skilled work. Contact any service technician. If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop
9/20/2021 1:29:39 PM • Toshiba... • Answered 2 days ago
Owners manual Toshiba SEro295
The SE-R0295 remote was sold with select Toshiba DVD/VHS recorders, including the DVR620. The manual for the recorder will have the instructions for the remote. Crutchfield has the manual for the DVR620 on the product page: https://www.crutchfield.com/S-c7W4uYBFvX6/p_052DVR620/Toshiba-DVR620.html . The current link to the manual is https://pdf.crutchfieldonline.com/ImageBank/v20101107082900/Manuals/052/052DVR620.PDF . See page 12 and subsequent pages for information on using the remote. This does not appear to be a universal remote that can control other devices besides the DVD/VHS recorder. I hope this helps. Cindy Wells
9/13/2021 7:02:34 PM • Toshiba... • Answered on Sep 13, 2021
Toshiba B-EV4D firmware
Do not waste countless hours on your college assignments anymore. Get <a href=" https://speedygrade.com/p/test-bank-for-biochemistry-4-e-4th-edition/ ">Test Bank For Biochemistry 4 E 4th Edition</a> and work smart with better results.
9/9/2021 8:50:56 AM • Toshiba... • Answered on Sep 09, 2021
Model 46XV540U TV. Why is backlight out?
The back light and the LCD in your TV has burned out and had quit working and the screen for your TV will have to be replaced.
8/23/2021 8:13:06 AM • Toshiba... • Answered on Aug 23, 2021
I have a Toshiba 40ft1u tv that needs a main board 461C2P51L12' 431C2P51L12' STF32T' VTV-L32606
Here is a board, it's from Canada but with shipping is not to bad priced at $60. I know nothing about the seller so it's possible you could get a defective board. I assume your missing the ps_on signal from the main and that's why the set won't turn on
8/22/2021 1:59:06 PM • Toshiba... • Answered on Aug 22, 2021
My Toshiba TV VCR Combination has sound but no picture, just snowy
What color cables are you using?
7/29/2021 9:00:48 PM • Toshiba... • Answered on Jul 29, 2021
I have uet-606 universal remote control, but i
Buy another one on Ebay universal remote control5.00 dollars from china
7/20/2021 11:54:00 AM • Toshiba... • Answered on Jul 20, 2021
2answers
Toshiba 65H83 is flickering after maybe an hour on. Is this a convergence chip issue?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in Webview by mobile. Mobile View has no search box.
6/27/2021 3:32:49 PM • Toshiba... • Answered on Jun 27, 2021
Toshiba 24AF45 24" TV Logo
Popular Tags
13 questions posted
Top Toshiba Televison & Video Experts
Ekse
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba 24af44
  • Televison & Video
