Vacuums Logo
A
Anonymous Posted on Nov 09, 2013
Riccar wheel off - Riccar Vacuums
Thatvacguy.com
Level 3:
  • Riccar Master 1,619 Answers
  • Posted on Aug 11, 2014
Thatvacguy.com
Riccar Master
Level 3:
Answers
1619
Questions
0
Helped
605137
Points
3345
Depends on the model
How do you get a broken wheel off a Riccar canister vacuum model moon 2 to replace it with a new one
I usually just break them off. The new one will literally pop on. Don't forget to take of the hubcap and put it on the new wheel.
I need to change the back wheel on my riccar supra lite
Slide a small screwdriver beside the wheel and rotate it to push up on the axle holding the wheel in place
1helpful
Riccar 8650 vacuums reset.....cannot find as stated just above left wheel and to the right....all smooth dark blue plastic housing
Your 8650 is likely about 30 years old. It may not have a reset switch. If it won't run it may need a new cord or switch. If it's in good shape it may be worth having it looked at by your local Riccar dealer.
2answers
Where can I find wheels for riccar 8850 baseplate?
you will need to get the whole base plate look on ebay
Riccar moonlight replace wheel
There are clips on the inside of the wheel hold the wheel on. You can break the old ones to remove it. The new one will snap in place.
Riccar sunburst vacuum wheel
There are little prongs that hold the wheel on. New wheels are inexpensive if it needs to be replaced. Break the prongs off with a skinny screwdriver to remove the wheel. The new wheel will just snap in place.
6helpful
Where is the reset button on the Riccar 8995
The reset button on the Riccar 8955 is located on the back of the vacuum cleaner, at the very bottom, right above the rear wheels. You can push the reset button with a ball point pen or something similar.
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at [email protected].
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
3helpful
3answers
Riccar 8750
I have an 8625 and the button is now white not red. Probably fadded. Thanks that was the reset button and it solved my problem.
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
