Question about Riccar Vacuums
I need to change the back wheel on my riccar supra lite
Posted by Debra Braman on
Thatvacguy.com
  • Riccar Master
  • 1,604 Answers
Slide a small screwdriver beside the wheel and rotate it to push up on the axle holding the wheel in place
Posted on Oct 23, 2018
Riccar 8650 vacuums reset.....cannot find as stated just above left wheel and to the right....all smooth dark blue plastic housing
Your 8650 is likely about 30 years old. It may not have a reset switch. If it won't run it may need a new cord or switch. If it's in good shape it may be worth having it looked at by your local Riccar dealer.
Aug 05, 2018 | Riccar Vacuums
Where can I find wheels for riccar 8850 baseplate?
you will need to get the whole base plate look on ebay
Jun 04, 2018 | Riccar Vacuums
Riccar moonlight replace wheel
There are clips on the inside of the wheel hold the wheel on. You can break the old ones to remove it. The new one will snap in place.
Feb 16, 2014 | Riccar Vacuums
Riccar RSL4 Supra Lite Very Noise/Slight Burning Smell
I am looking for a new motor for my 8920 Ricaar Vacuum. Can you lead me in the right direction. I can put it in my self. I replace them before. I used Ricaar for 25 years. Love them
Jan 02, 2014 | Riccar Vacuums
Reset button power
Reset switch is located on the back of the vacuum and close to the back wheels.Press a reset switch a few times and vacuum should start. Check also cord plug . Many times metal prongs are broken at the end of the cord (usually one of them)
Nov 28, 2013 | Riccar 4812 Vacuum
Riccar sunburst vacuum wheel
There are little prongs that hold the wheel on. New wheels are inexpensive if it needs to be replaced. Break the prongs off with a skinny screwdriver to remove the wheel. The new wheel will just snap in place.
Nov 15, 2013 | Riccar RC1100 Compact Vacuum
Absolutely no power. No light or anything. Is
There's a small white button on the back of the machine near the left wheel. Use a paper clip or similar item to push that in.
Jul 04, 2010 | Riccar 8955 Upright Vacuum
Where is the reset button on the Riccar 8995
The reset button on the Riccar 8955 is located on the back of the vacuum cleaner, at the very bottom, right above the rear wheels. You can push the reset button with a ball point pen or something similar.
Feb 15, 2010 | Riccar 8955 Upright Vacuum
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at [email protected].
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
Jan 11, 2010 | Riccar 4812 Vacuum
Vacuums Logo
103 people viewed this question
Top Riccar Vacuums Experts
brian kossman
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
