Question about Riccar Vacuums
Riccar moonlight replace wheel - Riccar Vacuums
Thatvacguy.com
  • Riccar Master
  • 1,604 Answers
There are clips on the inside of the wheel hold the wheel on. You can break the old ones to remove it. The new one will snap in place.
Posted on Jan 13, 2015
I need to change the back wheel on my riccar supra lite
Slide a small screwdriver beside the wheel and rotate it to push up on the axle holding the wheel in place
Aug 31, 2018 | Riccar Vacuums
Where can I find wheels for riccar 8850 baseplate?
you will need to get the whole base plate look on ebay
Jun 04, 2018 | Riccar Vacuums
Riccar sunburst vacuum wheel
There are little prongs that hold the wheel on. New wheels are inexpensive if it needs to be replaced. Break the prongs off with a skinny screwdriver to remove the wheel. The new wheel will just snap in place.
Nov 15, 2013 | Riccar RC1100 Compact Vacuum
How to change bag
Open the bag door, slide the bag out of the bag holder, slide the new bag in and close the door.
Sep 11, 2013 | Riccar Moonlight/Sunburst Hepa Vacuum Bags
Riccar vacuum Moon 1 just won't turn on, any ideas?
Check cord, esp at entry point. Otherwise it may be switch, motor windings burnt out, broken wire, carbon brushes worn. Some appliances also have a thermal fuse, which is a silver tube shape.
Apr 13, 2013 | Riccar Moon, Pazza Vacuum Cleaner...
Where is the reset button on the Riccar 8995
The reset button on the Riccar 8955 is located on the back of the vacuum cleaner, at the very bottom, right above the rear wheels. You can push the reset button with a ball point pen or something similar.
Feb 15, 2010 | Riccar 8955 Upright Vacuum
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at [email protected].
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
Jan 11, 2010 | Riccar 4812 Vacuum
Riccar rc1100 won't turn off
I am an riccar dealer, and you either have a short in the wire leads from front of vacuum to circuit board or a bad circuit board which if so the boardd will have to be sent to manufacture to be rebuilt as there are no new circuit boards available. if not under warrenty which i doubt since riccar hasnt made these models for a while. would recomend replacement with either sunburst or moonlight model as they are a comparable replacement to the repair. or just simply just plug and unplug machine, if it doesnt bother you to do so. If more questions email me at [email protected] subject riccar, or go to www.riccar.com to locate nearest dealer
Mar 22, 2008 | Riccar RC1100 Compact Vacuum
Riccar 8750
I have an 8625 and the button is now white not red. Probably fadded. Thanks that was the reset button and it solved my problem.
Oct 23, 2007 | Riccar 8650/8625 s Vacuum
Vacuums Logo
220 people viewed this question
Top Riccar Vacuums Experts
brian kossman
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
