Question about Riccar 8955 Upright Vacuum
My Riccar Vacuum cleaner just stopped working abruptly and now won't even turn on. I changed the bag, checked to see if it was installed correctly, it worked for a minute but a red light began flashing indicating the bag wasn't installed properly. I checked the bag again, it was fine...but the light wouldn't go off. So I checked it again. Finally, it just lost power and now will not turn on. I have four dogs and need this thing to work. Thanks
Posted by susanchri43 on
  • 2 more comments
  • susanchri43 Jul 04, 2011
    THANK :YOU SO MUCH! IT worked. Had no idea there was a reset button, even though we went over and over the vacuum - looking for ANYTHING that we could fiddle with. I think it did overheat.....I will check the vacuum to see if there are any clogs, etc. BUT, you are the best. THANKS again.
    Yes, this worked great and I will definately use this service again. The best part is that my husband didn't think this was worth the money and wanted to take the vacuum to the repair shop....an easy $75 repair -- he told me to tell you..."Tell them that I admit I was WRONG! And I tried to fix the machine, but couldn't -- so THANKS. "
  • Ed Lawson May 10, 2013
    thank you!! That saved a service call.
  • John Kincaide
    John Kincaide Dec 01, 2019
    Thank Reynaldo Labaguis Jr.!!! Your post from even 8 years ago saved me a trip to the vacuum cleaner dealership for such a simple repair. Key was your excellent description matching the symptoms of the problem, and easy steps to follow. The blockage was about 2.5cm (1 inch) from the intake tube behind the roller. It was of dust balls, and pieces of paper. Riccar design is well done for easy light home repair.
    Symptom - Riccar vacuum cleaner stopped while using it to vacuum carpets. Turned it off and made sure the cord plug was tightly plugged into the wall socket. Turned it on - the switch glowed green indicating power but no vacuum motor response. I plugged the vacuum into another plug. Same Result. The vacuum was slightly warm to the touch. It had a new nearly empty vacuum bag.
    Fix Time: 10-15 minutes
    What's needed: Wire coat hanger, and a quarter.
    With the Riccar VIBDL.2 vacuum UNPLUGGED laying on a bed on its back on the bed, with roller horizontal front of vaccum facing upwards towards the ceiling, I was able to gain access to the intake vacuum tube by removing the cover plate that connects to the front edge of the vacuum front and down to about midway just above the roller.
    1) DO THIS FIRST - the screw in the middle above the roller - you don't have to remove - there is locking slider that you push to the left to gain access to an opening around the screw. This way you don't need a screwdriver (With this Model) to remove the screw.
    2) on the outer edges of the plate there are extended Tabs of plastic that have "PULL" on them. You can tug on them (ONLY AFTER DOING STEP 1 FIRST) - but I found that if you took a quarter and wedged it between the frame of the vacuum head and the tab and gently rotated the quarter, and the tab easily popped off. I did not want to pull hard thinking I may break the plastic tabs.
    3) Using tweezers, then later carefully, a wire coat hanger that was unwound from the top clip and extended, I was able to pull the blockage out.
    4) After getting the blockage out reversed steps 2) and 1) above.
    ** Important ** is finding the white small heat reset switch on the lower left on the back of the vacuum to get the vacuum motor to power up.
    Turned it on - and it worked!
    Genius:
  • 1,157 Answers
Hi susanchri43,
Have you tried resetting the machine using the reset button on the back of the vacuum? If not please press the reset button. Here are additional troubleshooting steps that you may apply to determine what's wrong with it.
1. Ensure that the power cord is firmly in. You may also try to unplug and replug the power cord.
2. This vacuums are equipped with a thermal motor protection circuit that will shut the vacuum down if it detects excessive heat up. Overloading due to a clog, or the bag being full can cause heat up.
3. Check the hose pipe or the upright's mouth and remove any obstacles. Use a broom handle to poke any debris that may become trapped in the hose.
4. Unplug the machine and use your fingers to pull out any debris in the machine's mouth. Cut any thread or string that may have become wound around the rollers. Plug the machine back in and press the reset button on the back of the vacuum.
5. Switch the carpet switch to the "Carpet" position if you are using the vacuum on carpet and the vacuum won't pick up debris. Turn the tool activation switch to the "Off" position. Take a look at the light marked "Brushroll." If it's illuminated, remove the cause of the jam at the brushroll.
6. If the vacuum allows dust to escape, check if all the covers are tight. The filters and vacuum bag must be installed correctly. The filters snap into place and cannot be washed and re-used. Make sure the base of the bag collar is on the bag supports.
Hope it helps.
Thank you for using FixYa.
Posted on Jul 04, 2011
  • Reynaldo Labaguis Jr.
    Reynaldo Labaguis Jr. Jul 04, 2011
    I'm glad to hear that the unit is working now. If you're satisfied with the solution you can now go ahead and accept it.
    Thank again for using FixYa.
Nick Ortiz
    Welcome Back:
    Visited the website for 2 consecutive days.
I'm so sorry guys regarding your broken hoovers. I haven't fixed my broken ones, just bought new ones for a couple of times. Recently I acquired a hoover on https://miglioriaspirapolveri.com/scopa-elettrica - the site recommended me by my Italian friend. So if needed, you also may review cordless cleaner at the site, too.
Posted on Feb 24, 2019
My Riccar vacuum was working but then just stopped and won't turn on. I changed the bag even. What's up?
Hi Patty.
Could be:
Power cord. Check esp. strain-relief where cord enters housing.
On/off power switch. Needs strip down & continuity check.
Motor burnt out. Smell if burnt. Strip search.
Carbon brushes inside motor worn. Dismantle & check / renew.
Does this help?
Regards, Clive.
Nov 05, 2017 | Riccar Vacuums
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
After changing the bag on my riccar it is very hard to push'
after putting a clean bag into the vacuum cleaner, more air can get through it, so it generates more vacuum, sp it is obvious, that it will be harder to push for some time. if it wont get better, it only means you didnt gt it with a clean airbag
Apr 22, 2013 | Riccar 8955 Upright Vacuum
Riccar vacuum Moon 1 just won't turn on, any ideas?
Check cord, esp at entry point. Otherwise it may be switch, motor windings burnt out, broken wire, carbon brushes worn. Some appliances also have a thermal fuse, which is a silver tube shape.
Apr 13, 2013 | Riccar Moon, Pazza Vacuum Cleaner...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Stopped running. Filter was clogged. Cleaned filter and changed bag, but still won't start. Motor was warm when it stopped.
Hi There,
This sounds like the Thermal Switch in your motor tripped. All Riccar vacuum cleaners have a motor reset switch, that will shut the motor down when it gets hot. Usually it's caused by a full bag, clog, or dirty filter.
Try resetting the thermal switch first. If this doesn't work, you may have done some more serious damage to the motor, and it might be a good idea to take it into a local Riccar dealer in your area.
Here's a step by step guide on how to check the reset switch on your Riccar 8850:
  1. Unplug the vacuum cleaner
  2. Check for problem – over–filled bag, clog in hose, clogged filters, etc.
Remove the vacuum bag, and see if you can visibly see any obstructions, or replace the bag if it's full:
Also inspect the Secondary filter while you have the vacuum bag removed from the machine. If the filter is clogged or dirty, rinse under warm water, and air dry completely before reinstalling it into the vacuum. It's best to wash this filter every 30 days, and replace after 4-5 washings.
Here's a link to the secondary filter on our website if you ever need to purchase one:
Riccar 8800 Series Secondary Filter
Your Riccar 8850 also has a set of exhaust filters that are on the front of the vacuum, near the bottom where the upright body meets the agitator housing. These filters when clogged may also cause the thermal switch to trip. These filters are recommended to be replaced every 6-12 months, and are not recommended to be washed.
Here's a link to 2 sets of the exhaust filters for the Riccar 8850 on our website:
Riccar 8850 Exhaust Final Filters, 2 Sets, 4 Total Filters
It's also possible that you may have clog in the suction port inside of the agitator housing. Remove the bottom plate from the vacuum, and look for the tube that runs on the left hand side from the tray to the rear of the agitator housing. Make sure that this tube is clear from obstructions:
Locate "tripped" fuse – the small white button located on the bottom of the back side of
Using a pencil, paper clip or other pointed object, push the reset button in, you should hear a clicking noise when it resets.
Plug the vacuum cleaner back into the wall, and try turning the vacuum on. It should come right back on. If not, it's best to take your machine into a local Riccar authorized repair facility for further more advanced diagnosing.
Please feel free to ask any follow up questions by adding a comment to this repair, I'm always more then happy to answer any and all follow up questions if you need some clarification. If this was helpful, please rate the repair helpful or leave some feedback for me. Thanks so much,
Chris Jones
Govacuum.com
May 22, 2010 | Riccar 8850 Vacuum
My Riccar 8850 stopped running. Changed the bag and cleared all hoses. Light comes on but the motor doesn't operate. I can turn the brush freely by hand.
Greetings from GoVacuum,
If the light on your Riccar 8850 is coming on, but the motor is not coming on, this indicates that your motor has gone bad. There is a reset switch on the back of the vacuum cleaner that sometimes trips if the bag is too full, or the filters are not maintained, but when this happens nothing on the vacuum comes on including the headlight. If the headlight is coming on, this indicates that electricity is making it down to the headlight, and the current is going through, but just not activating the motor. This is a tell tale sign of your motor being bad, and needing replacement. You can purchase the motor for the Riccar 8850 (12 AMP, 2 stage motor, Riccar part D113-1700 $122.44) from GoVacuum by giving us a call, as we don't yet have this part on our website.
I hope this helped you. We have been fixing Riccar's for over 30 years, and they are great vacuum cleaners, and the age of the model 8850 is probably the life expectancy of this vacuum cleaner.
Chris Jones
GoVacuum.com
Mar 18, 2010 | Riccar 8850 Vacuum
Where is the reset button located?
The reset buttons on the Riccar vacuum cleaners are located at the bottom of the vacuum cleaner in the back, underneath of where the wand sits on the vacuum cleaner.
Here's a picture of a Riccar 8925 which replaced your 8850 a few years ago, but the reset switch will be in the same exact location on all Riccar uprights;
Here's a closer look of the reset switch;
I hope that I was able to answer your question. You can avoid the reset switch flipping in the first place by always ensuring that you change the bags frequently and when full, as well as the motor filter that sits underneath of the bag. Also keeping the vacuum from clogging will prevent this.
If you found this repair solution helpful to you, may you please click the 4 Thumbs Up Icons in the top right hand corner to help me out here on Fixya? I really do appreciate it, thank you so much.
Chris
GoVacuum
Jan 15, 2010 | Riccar 8850 Vacuum
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at [email protected].
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
Jan 11, 2010 | Riccar 4812 Vacuum
Riccar 8955 Upright Vacuum Logo
8,189 people viewed this question
Top Riccar Vacuums Experts
brian kossman
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
