Question about Riccar Vacuums
Riccar 8650 vacuums reset.....cannot find as stated just above left wheel and to the right....all smooth dark blue plastic housing
Posted by JOHN BRUNK on
Thatvacguy.com
  • Riccar Master
  • 1,604 Answers
Your 8650 is likely about 30 years old. It may not have a reset switch. If it won't run it may need a new cord or switch. If it's in good shape it may be worth having it looked at by your local Riccar dealer.
Posted on Aug 05, 2018
4 Related Answers
Anonymous
SOURCE: riccar 8750
I have an 8625 and the button is now white not red. Probably fadded. Thanks that was the reset button and it solved my problem.
Posted on Apr 19, 2008
Anonymous
  • 17 Answers
SOURCE: riccar 1500p vacuum won't start
it has a thermal fuse that shuts it down if it over heats. Check the hose , wands and floor tool for blockage and check your bag and filters as well.
Posted on Oct 02, 2008
Anonymous
SOURCE: reset button on riccar upright vacuum
I CANT SEEN TO GET THE TOP TANK TO SNAP BACK IN, IT KEEPS SPILLING THE WATER AND SOLUTION
Posted on Dec 21, 2008
VacuumRepair
Chris Jones
  • 438 Answers
SOURCE: Changing Belt on Riccar 8650
Greetings from GoVacuum,
I will attempt to walk you through the belt change on your Riccar 8955 upright vacuum cleaner. I have taken pictures for you for each step to ensure that it's done properly. What you'll need to have handy for this repair;
- Phillips Head Screw Driver
- Riccar 4000 / 8000 Series Belt
- Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
Step 1: Make sure the vacuum cleaner is unplugged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unscrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush
Step 3: Remove the belt guard that sits to the left of the roller brush, and is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift straight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take one new belt and wrap it around the metal pin in the back of vacuum cleaners agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), but the other end of the belt through your new roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continuously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, position the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right. Here's a picture of the belt guard being put back into place;
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Change the the rug / floor switch from bare floors to the carpet setting, and the turn the vacuum upside again so the brush and belt are exposed:
Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
Step 12: There is a flap that can be opened after the metal bottom plate has been removed, that will give you more access to the motor shaft. Make sure that this flap is closed;
Step 13: The last tricky part can be reinstalling the metal bottom plate. There is a little lip on the front of the vacuum cleaner that the edge of the bottom plate has to slide under for it to be installed properly. A lot of people just install the bottom plate over top of this lip, and this prevents the brushes from hitting the carpet as low as if the bottom plate is correctly installed. Here's a picture of the lip with the bottom plate in the backgroud;
Step 14: Slide the metal bottom plate into the lip on the vacuum cleaner, and fasten the screws back into the bottom plate to secure it. The lip is a little tricky, but after doing it just once, you'll have no problems in the future changing your belt.
Here's a picture of the bottom plate installed INCORRECTLY with the bottom plate over top of the lip;
Here's a picture of the CORRECT way to install the bottom plate:
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the 4 Thumbs Up Icons in the top right hand corner of the solution. Feel free to request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions.
Thank you very much,
Chris J.
Posted on Mar 21, 2010
Looking for a parts list / manual to replace the motor
You will need to purchase the motor from a Riccar dealer. If you don't have a local dealer contact me at [email protected]
Jan 21, 2016 | Riccar 8650/8625 s Vacuum
How to install belt on Riccar 8750 commerical vacume cleaner?
No. There is only one belt. Remove the bottom plate to gain access to the belt.
Jan 18, 2014 | Riccar 8650/8625 s Vacuum
Faulty switch
Your 8650 is an old vacuum. The switch is in the part of the vacuum where the handle goes down into. When you push the lever on the handle it activates the switch. To get to the switch take off the dust cover, remove the three Screws on the small cover where the handle goes in to see the switch. On older Riccar vacuums like yours sometimes the screw holding the handle in is loose which can cause the switch to not Always engage properly. To test this turn the vacuum on and wiggle the handle. If the vacuum vacuum cuts out you may only need to tighten the handle screw.
Jan 31, 2013 | Riccar 8650/8625 s Vacuum
The motor on my riccar 8650 is very loud. is there brushes that can be replaced?
Your. 8650 is likely well over 20 years old. It has carbon brushes in the motor that may need replaced but your best bet Is to take it to your Riccar dealer to diagnose it or you might replace the wrong thing. You have a very durable long lasting machine obviously but there are minor things that need occasional service to keep it running properly for many more years. This series started with the 8600 models of which I still have many brought in for annual service. There has been an 8700 and 8800 series and now the latest 8900 series which has been out well over 10 years.
Apr 29, 2012 | Riccar 8650/8625 s Vacuum
What type of bag does it use
This uses a Riccar 8000 series bag, or a Simplicity type B bag.
Mar 07, 2011 | Riccar 8650/8625 s Vacuum
I have a Riccar 8750, when I plug it in any outlet and turn on the headlight does not come on and the vacuum does not turn on. The reset button does not seem to help. It worked fine when I shut it off last...
An 8750 is likely at least 20 years old but still may have lots of life left. I still have 8600 series Riccar vacuums brought in to my vacuum shop for service. You may have a loose wire, bad switch or power cord. I would take it to my local Riccar dealer to diagnose and repair.
Jan 07, 2018 | Riccar 8650/8625 s Vacuum
Stopped running. Filter was clogged. Cleaned filter and changed bag, but still won't start. Motor was warm when it stopped.
Hi There,
This sounds like the Thermal Switch in your motor tripped. All Riccar vacuum cleaners have a motor reset switch, that will shut the motor down when it gets hot. Usually it's caused by a full bag, clog, or dirty filter.
Try resetting the thermal switch first. If this doesn't work, you may have done some more serious damage to the motor, and it might be a good idea to take it into a local Riccar dealer in your area.
Here's a step by step guide on how to check the reset switch on your Riccar 8850:
To reset the thermal fuse:
  1. Unplug the vacuum cleaner
  2. Check for problem – over–filled bag, clog in hose, clogged filters, etc.
Remove the vacuum bag, and see if you can visibly see any obstructions, or replace the bag if it's full:
Also inspect the Secondary filter while you have the vacuum bag removed from the machine. If the filter is clogged or dirty, rinse under warm water, and air dry completely before reinstalling it into the vacuum. It's best to wash this filter every 30 days, and replace after 4-5 washings.
Here's a link to the secondary filter on our website if you ever need to purchase one:
Riccar 8800 Series Secondary Filter
Your Riccar 8850 also has a set of exhaust filters that are on the front of the vacuum, near the bottom where the upright body meets the agitator housing. These filters when clogged may also cause the thermal switch to trip. These filters are recommended to be replaced every 6-12 months, and are not recommended to be washed.
Here's a link to 2 sets of the exhaust filters for the Riccar 8850 on our website:
Riccar 8850 Exhaust Final Filters, 2 Sets, 4 Total Filters
It's also possible that you may have clog in the suction port inside of the agitator housing. Remove the bottom plate from the vacuum, and look for the tube that runs on the left hand side from the tray to the rear of the agitator housing. Make sure that this tube is clear from obstructions:
Locate "tripped" fuse – the small white button located on the bottom of the back side of
the main body (roughly one inch to the right of the left wheel)
Using a pencil, paper clip or other pointed object, push the reset button in, you should hear a clicking noise when it resets.
Plug the vacuum cleaner back into the wall, and try turning the vacuum on. It should come right back on. If not, it's best to take your machine into a local Riccar authorized repair facility for further more advanced diagnosing.
Please feel free to ask any follow up questions by adding a comment to this repair, I'm always more then happy to answer any and all follow up questions if you need some clarification. If this was helpful, please rate the repair helpful or leave some feedback for me. Thanks so much,
Chris Jones
Govacuum.com
May 22, 2010 | Riccar 8850 Vacuum
Where is the reset button the riccar 8850?
If you look down at the base of th vacuum cleaner at the vacuum bottom in the back, right above the rear wheels, you will see a small red button. Take a ball point pen, and while the vacuum is plugged in, go ahead and push the red button or the reset switch. Did the vacuum come on?
If not, it may another simple problem of the cord/ plug going bad.
I think if it just stopped workint all or a sudden, it's prbably the reset switch.
If this was helpful to you, please help other Fixya users find the repair by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
Apr 09, 2010 | Riccar 8850 Vacuum
Where is the reset button on the Riccar 8995
The reset button on the Riccar 8955 is located on the back of the vacuum cleaner, at the very bottom, right above the rear wheels. You can push the reset button with a ball point pen or something similar.
Feb 15, 2010 | Riccar 8955 Upright Vacuum
Riccar 8750
Oct 23, 2007 | Riccar 8650/8625 s Vacuum
Vacuums Logo
50 people viewed this question
Top Riccar Vacuums Experts
brian kossman
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
