Panasonic Lumix DMC-ZS3 Digital Camera Logo
Stephanie Piquet-Cannaert Posted on Oct 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot delete sd card
I can delete photos directly from the camera, but when I insert the sd card into the computer I am not able to delete. The sd card tab is not in the lock position.
halotheracer
Level 2:
  • Expert 69 Answers
  • Posted on Oct 29, 2013
halotheracer
Expert
Level 2:
Answers
69
Questions
0
Helped
11932
Points
156
Check the operation system permissions given to the current user.
Check the file properties (security tab) you want to delete if the delete permission is given. If not, edit the permissions.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Dec 25, 2007
SOURCE: Photos stuck on integral memory?
When viewing pictures, select the 'Menu' option. Scroll down and on the second page there's a 'copy' function that can either transfer photos from internal memory to a memory card or vice versa.
I didn't know this was possible until today, either. Handy!
Anonymous
  • 104 Answers
  • Posted on Mar 26, 2008
SOURCE: SD PHOTO CARD ERROR - HELP ME!
sir, this is the USB or cable problum
Anonymous
  • Posted on Jul 05, 2009
SOURCE: SD card - memeory card parameter error
The manual for the camera states that the memory card must be formatted in the camera and that cards formatted in a computer may not work properly. Use the format command in the camera.
Anonymous
  • 11967 Answers
  • Posted on Dec 11, 2009
SOURCE: My DMC-FS4 has message 'This memory card is locked'
Move the slide switch on the side of the card.
Anonymous
  • 6487 Answers
  • Posted on Mar 02, 2010
SOURCE: My memory cards say they are full. I have deleted
Wit this error that you have I would suggest that you format the card and then after that check if you still have the same error and if still same problem remove the card from camera and put it back in.
1helpful
4answers
How to recover deleted photos from memory card?
Get freeware recovery software on web..DON'T use card any further to avoid putting new images on spots where old ones were deleted.
Then you can recover deleted items.
Jun 06, 2016 • Cameras
2helpful
How do I access the SD card after I insert it?
Your camera should access your SD card as soon as you insert it. You can plug your camera into your computer and access the card through the camera, or you can get an SD reader and connect that to your computer. Pull the SD out of the camera and put it into the card reader, and your compute will have access to the card.
May 20, 2015 • Cameras
I reformat my sd card in the computer to remove all the photos the when im using it in my sony cybershot camera it appears "reinsert memory card" how can i fix the it to use it again in the camera
When you need to delete the photos from the SD memory card, do not use your computer to do it. Use your camera to format the SD memory card.
To fix this problem, insert the SD memory card in your camera then go to the camera's Menu and format the SD memory card.
3helpful
3answers
Accidentally deleted photos from sd memory card
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones:
2answers
I have a canon A3100IS, few hours ago i was deleting photo from sd card of my canon in my pc using card reader, after deleted some image, when i restarted my camera i saw a note on my canon that...
If you have all the photos off your camera, you should try reformatting it. In Windows, insert the card into your card reader. Find the removable device in My Computer. Right click, and format it. Use FAT32. Reinsert the card into your camera, and it should work.
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
13helpful
6answers
How to delete photos I have downloaded to olympus master
you can recover deleted photos from SD card with steps below
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Apr 29, 2008 • Cameras
8helpful
6answers
Can photos that were accidentally deleted from a SD card be recovered
yes, you can recover deleted photos from sd card with sd card recovery software like asoftech photo recovery, here's the steps that helped me
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
