Cameras Logo
Question about Polaroid Cameras
How do I review the sd card on Polaroid i534 - Polaroid Cameras
Posted by Jean Williams on
How to view the pictures from the sd card?
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and SupportHow to easilydownload Pictures from Digital Camera
heatman101
1helpful
When I first got my diital camera I accidently hit save to card without a sd memory in camera. Now camera memory says it's full. Have tried trial software to recover photos but not working. Canm only get...
Go into the menu and find "copy" and copy the internal memory to a memory card. Then, with no card in the camera, go into the menu and find "format"....follow the on-screen instructions to erase the internal memory.
1helpful
I534 camera protected card. how do i unprotect camera will not take pictures
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
I have a i534 Polaroid digital camera and its locked on protected mode. I'm unable to take pictures and can't find my manual.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 07, 2010 • Cameras
3helpful
How to unlock protected card on i534
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Format memory card on i534
Hi Mr Varshap4
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Camera said memory full but I have memory card
You need to format the SD card before it will be used by the camera. Formatting instructions are in the manual.
3helpful
3answers
Need a copy of owners operator manual lost mine need a new one.
Below is the link to the manual for your camera. You can download it for future use (pdf) format.
http://www.polaroid.com/service/userguides/digital/cameras/i532_ug_en.pdf
Enjoy, and thank you for choosing Fixya!
Cant figure out how to delete photos
Have you loaded the software that came with the camera?
Do you have the usb cable to connect the camera to the computer?
Are you using internal memory or an SD card?
If you do not have the user manual go to this link
To get to the pages below:
Left click on the page number next to the right arrow and put the page number you want in and hit the enter button the the keyboard.
On page 4 of the user manual #6 Manager Pictures and Video Clips you have a selection
Go to page 54 of user manual it shows you in detail how to review your pictures.
JUST A NOTE
The cameras internal memory is very small, you will need an SD card Page 28 in the manual
Any other problems, let me know
Mar 27, 2008 • Cameras
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Steve
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
