Hello Andy,
The tray 1 is part of the front door assembly. The part number is RM1-4848 and it is available from several web sites.
SOURCE: Cant figure out how to open Tray 1 to clear paper jam
Leave Tray1 closed. Remove tray 2. Push down on green arrows visible after removing Tray 2. You should see the jammed paper on the plastic tray which becomes accessible after pushing down on the green arrows.
SOURCE: keeps reseting to Tray 1
Printer Defaults button? what magical land is that found in?
Here is the real solution:
In Printers and Faxes, right-click the printer
Click Printing Preferences
In Paper Source drop down, select Tray 2.
Peace!!
d(-_-)b
SOURCE: just bought an HP color laser Jet CP2025. How do
Hi I think it calibrates when you turn it on
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
SOURCE: HP Color Laser Jet CP2025.
HP Color LaserJet CP2025 - "Replace Supplies" message.
black cartridge is blinking. Printer won't print and message will not go away. Any suggestions?
