From the service manual:
The laser/scanner speed is incorrect.
1. Press [GO]. The page that contains the error will automatically be reprinted.
2. Turn the printer off and then back on.
3. Reseat the cables.
4. Replace the laser/scanner.
Check if your product is still under warranty Click HERE.
SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal
hardware error.
Recommended Action
SOURCE: My ph laserjet color printer 4650dn is showing
There is a fix for this issue @ http://www.fixyourownprinter.com/forums/printer/30528
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
SOURCE: printer hp lesarjet 5100 showing the
Press the "Go"button. If problem persists turn machine off and on. If this does not work you'll have to replace the laserscanner.
SOURCE: when scanning or copying
52 error is a scanner error.
Turn off the power by using the power switch, wait at least 30 seconds,
and then turn on the power and wait for the product to initialize.
If a surge protector is being used, remove it. Plug the product directly
into the wall socket. Use the power switch to turn the product on.
If the error persists, contact HP. For contact information, see
www.hp.com/support/ljm1522
or the support flyer that came in the product box.
