Posted on Apr 11, 2009
Konica photocopier I have just been given a konica 1020 photocopier, but no instruction manual. when i switch it on F36 appears. what does this function mean? Anybody could help me, i have a KONICA 7022 COPIER, there is an error message F35-1 call service, but i cant enter on the #25 mode on the software switch because there is a 4 digit password code on my machine, i bought this surplus and i dont know what is the password, how to reset or remove the password, plss help me tolitz
Anonymous
Level 1:
New Friend:
  • Contributor 51 Answers
  • Posted on Aug 31, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
51
Questions
0
Helped
94274
Points
90
How to reset code 35-3 on photocopier konica 7020
DO THIS once because you are re-setting the FUSER it can catch on fire that will ruin a perfectly good day!!!!! Get a tech out to look at it.
Turn on the main and sub power switches.
Keep pressing the * button until the message
"Please enter service password." appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press 2 and 5 to select 25 mode. Then select soft switch. Set 3, then set 1 then change 1 to 0. to clear the code.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Trouble code f36 on a konica 2125
fuser unit replace the fuser unit
Konica 7020 trouble code 36-1
dear need help to resite l detect value auto adjustment developer konica 7020
23helpful
2answers
Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
My konica 4355 is showing f36-1 error what could be the problem
Fuser Section overheaded (HOT SECTION) can be reset in 25 Mode. If it comes back Fuser needs replacement part(s)
2helpful
I connot remember the pasword to open reset code. it was an accident to ON the switching 2-6. THE PROBLEM NOW IS I CONNOT RESET THE CODE F36-1
I can give you a generic solution.... You did not give a model number. Some are different.... Is it a Konica or is a Minolta based copier???? Try this press the user choise botton then when then the display changes - press the meter count - then press Stop - 0 - 0- Stop. The display will change to Service mode.. That is if it is for your generic Konica Minolta copier.. Good Luck
Konica minolta 7030 drum replacment
Is this a photocopier? If so then you will need a technician to fit this for you
3helpful
Error code F35 on my konica 1212 photocopier
That's a fuser error condition...I'll have to get back to you because i have to check in my book to remember how to reset it...Thank you for your patient !
2helpful
2answers
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
