SOURCE: Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
SOURCE: how to change gear kit
You can get a manual for this device here not sure what information the manual will provide for you would not hurt to check it out, also a good observation of what is needed to remove and replace this item is also something to write down where things go. The kit should have had instruction manual of how to install the kit. Check out the site above. Thanks for using FixYa! John
SOURCE: i have SB-99Ci Shredder .
Hi, you can use this manual and know more about using the shredder.
http://www.fellowes.com/fellowes/materials/documents/sb99ci_2010manual.pdf
You can pass on your comment, if you still need help.
Hope it helped.
