Fellowes Intellishred PS-79Ci Shredder Logo
Question about Fellowes Intellishred PS-79Ci Shredder
My Fellowes PS-79Ci Shredder will not turn on.
Main power switch is on as the bin light will come on when removing the bin. However the main power and shredder will not turn on once the bin is placed back in.
Posted by Trish D'Haese on
Anonymous
    New Friend:
PS-79C Issue was the bin light came on (when the bin was out), but the power wouldn't come on and no other lights. Just called the 800 number above (800-945-4545) and was told to jiggle the power switch - worked!! (The power switch on the top, not the one by the power cord). I guess it doesn't quite seat onto the internal circuit board switch quite right. Yay, working again! Then I got lectured to oil it once a month or every bin full, which I haven't been doing...
Posted on Dec 27, 2012
teddybear5805
Online with Fellowes tech support for 30 minutes and fixed problem (power button not working on Fellowes PS-79Ci). Over time, paper dust, dust and pollen accumulate under button contacts and eventually renders the switch inoperable. Tech had me push down the round power button between the two arrow buttons (not the I/O switch on the back) and roll my finger without touching the arrow keys in order to break loose the accumulated dust, etc. After 2-3 minutes of rolling, she had me vacuum the button by placing a vacuum hose over the button and keep repeating the process of hard rolling/vacuuming until contact was reestablished and the power button lit up (took me 2 cycles). She said continue repeating the rolling/vacuuming cycle until I was able to turn the power on and off with only one push of the button. Since I am an infrequent shredder, she also encouraged me to oil the blades once a month. This solution suggests further investigation into some temporary steps that could be taken between shredding projects to protect from corrosion or dust accumulation. But, in the meantime, I have a working shredder!
Posted on Apr 04, 2020
Lethe Erisdottir
    New Friend:
Buddyartz - I've had to do that 'jiggle the button' thing almost since I bought this sucker. Usually worked, up until now. I keep the machine clean, and I oil it regularly as suggested in the manual. But over time, the jiggle trick worked less and less well, and now it doesn't work at all.
gifford88 - I tried what you suggested - lifted off the top and cleaned off all the paper dust; I located the two screws close together, but there is no tiny glass sensor of any kind there. Just the solid plastic housing. I wiped it all down with alcohol anyway, but nope, nothing.
I put the top back on, jiggled the button like mad for about 10 minutes, then got so angry I gave the thing a hard smack. Light went on. So I shredded the few papers I had on hand, turned it off, then tried to turn it on again - nothing.
I'm about done with this - should have sent it back as soon as I started having to do the jiggle thing. If, per the answer they gave buddyartz, they KNOW this is a problem, why don't they manufacture a fix?????? NOT a good sign.
Posted on Dec 28, 2015
  • Paul Peters
    Paul Peters Sep 05, 2020
    The hard smack worked for me! Thanks!
5 Related Answers
Anonymous
  • 102 Answers
SOURCE: shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Posted on Feb 26, 2008
CLCLDL
SOURCE: Fellowes PS-70 Shredder jam
I used needle-nose pliers and regular pliers to pull out all of the jammed paper -- it took an hour but I finally got it. I never did find a release mechanism even after I took the top apart. Thanks anyway!
Posted on Jun 14, 2008
Anonymous
  • 105 Answers
SOURCE: The "bin full" indicator is always on.
you will have to clean or replace the bin full sensors
Posted on May 14, 2009
Anonymous
SOURCE: OD700C Fellowes Shredder blades don't turn
There is a screw hidden under one of the stick on labels. Remove that and the top comes just fine. I got it torn apart, completely cleaned of debris but the rollers still don't turn. I noticed an electrical arc when the switch is pressed so the unit is toast.
Posted on Mar 05, 2010
Testimonial: "Thanks. I found the hidden screw and was able to get inside. I know what's wrong with it now and hope to get it fixed. "
Anonymous
  • 472 Answers
SOURCE: my fellowes paper shredder is
Instructions
Step 1 Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
Step 2 Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
Step 3 Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
Step 4 Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
Step 5 Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
Good Luck!
Posted on Jun 19, 2010
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
My fellowes ps-70 shredder has a light on and it's not working
If the shredder is the kind that turns on when you insert paper, it may have an optical sensor that is dirty or blocked. Try blowing off the sensor with some canned air. The sensor is usually located in the center of the paper path slot. Also check that the bin is completely closed. Sometimes a tab on the door is bent or broken so that the shredder thinks the door is open. The tab activates a switch which tells the shredder that the door is safely closed. Fellowes has a lot of good tips on their website.
Fellowes Paper Shredder PS-79Ci power switch not working -- will not turn on!
Have you looked at the shredder blade to see if anything is still there? Turn power off, check shredder blade, clear anything stuck, put back together, turn power on and try again.
There seems to be a power ise when switch ingages breaker shuts off
I own a Fellowes PS 60 shredder.
I DO NOT THINK THE LINK WILL HELP YOU, BUT AT LEAST YOU WILL HAVE IT.
I advise you NOT to use your shredder if it is causing the cicuit to shut off_it may start a fire!
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Won't turn on...
You don't say what type it is, but they usually have little micro switches fitted to ensure the power won't come on until the blade section is fitting properly to the waste container part.
If it is the bucket type with the shred part on top just make sure it rests properly on top of the bucket so the microswitch on the bottom of the shred part gets depressed.
If it's a drawer type there may be a small projection on the drawer which pushes against a switch in the body of the shredder.
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Machine over heats and light oil light comes on. Where does the oil go?
Hi, you can place some oil on a piece of paper that you wish to shred & put that through your shredder. You do not need to saturate the paper, but use enough to lubricate your shredder.
Fellowes Powershred PS 60CC stopped working
8helpful
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Top Fellowes Office Equipment & Supplies Experts
David Shaub
W.L.
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
