Fellowes Saturn SL 125 12.5-Inch Laminator Logo
Anonymous Posted on Mar 22, 2012
Laminator Jammed! I have a fellowes saturn 125 laminator. there is an item stuck inside that is not sticking out on either side, so cannot be pulled out, even when the reslease lever is pushed. can i unscrew it and take it apart to get the item out? will i be able to put it back together and get it to work? thank you!!!
  • Anonymous Mar 24, 2012
    There are small screws located on the underside of the machine, by the feet. If I unscrew them and take the bottom off so that I can pull the stuck item out of the rollers, will I be able to put it back together and use it again? Thanks!
  • Anonymous Apr 23, 2013
    Yes. Take the four screws out from under the feet and the three from under the handle. Then turn it back the right way up and carefully separate the top from the bottom. There are wires joining top to bottom so don't be to forceful. Then you can access the internal rollers etc.
ROD GANDY
Level 3:
  • Master 1,602 Answers
  • Posted on Oct 01, 2015
ROD GANDY
Master
Level 3:
Answers
1602
Questions
0
Helped
591237
Points
4916
Once you take it apart it voids all warrants if you have any.
if you do not have any warrant parts than that the only way you are going to fix the issue.
here is what some one gave me some tips on disassembly of equipment. draw a picture of the device, mark the area of screw layouts, after separating the 2 parts draw diagram of each part, make foot notes on what you did, screw locations, parts removed, parts cleaned, PUT EVERYTHING IN A LINE IN THE ORDER OF REMOVAL PARTS, than work backwards and put everything back the way you took it apart, you should not have any extra parts and it should work fine. than if it every happens again you have your notes and information on hand to help you. you could try this site.
www.ask.com/
www.manualonline.com/
/mfg.name/make/model#/
www.mfg.name.wow/manuals/service/
www.manuals.wow.com/make/model#/service/repair/
www.disassembly.wow.com/mfg.name/make/model/instructions/
2answers
How can I open a Fellowes Venus 2 125 Laminator as I have a small pouch stuck in it and it won't come out
I had this happen where I worked and I elected to fix it. You have to remove the screws in the base, and IIRC the ends. Then I used a knife to cut the laminate pouch and pull out the pieces with pliers. If you can turn it on without damaging the machine or zapping yourself, the heat will help. My boss ordered a replacement which turned up a few days later :>D
https://www.google.com/search?q=Fellowes+Venus+2+125+laminator+jammed
Why won't my laminator turn on?
There is a heating unit inside of a hot laminator. Sometimes when you use this machine for too long it can damage some of the internal components because most of those things are full of plastic. You may want to see if Fellows can take it back under warranty. If they can't you are going to have to get a new one.
1helpful
Need a gear box for a Fellowes Voyager 125 laminator
Hi, I have a one that the PCB board is gone, the motor and shredder is perfect. You can buy the top with the motor frame from me if you like. It works sometime in reverse, but the safety light does not come on. Alternative sell me your PCB card
Fellowes laminator
Plz try the "Jam free" lever located on the top LEFT of the laminator. You ca try to feed another film in....hoping it will force the pouch out. Otherwise, you will have to take the cover off and unroll the pouch from the inside rollers. Good luck!
2answers
How do i get my Fellowes Venus 125 Laminator 5215901 to stop bleeping and heat up ?
Unfortunately, this message was posted in the section for paper shredders. If you still need an answer you will need to repost it.
Beeping and not turning on
This is the second laminator of the same model that is beeping and not turning on. What do we need to do to get this machine operational?
Top Fellowes Office Equipment & Supplies Experts
midnightmove
Level 1 Expert
Sean Wright
Sean Wright
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
