20 Most Recent
Fellowes Intellishred PS-79Ci Shredder Questions & Answers
My Fellowes PS-79Ci Shredder will not turn on.
PS-79C Issue was the bin light came on (when the bin was out), but the power wouldn't come on and no other lights. Just called the 800 number above (800-945-4545) and was told to jiggle the power switch - worked!! (The power switch on the top, not the one by the power cord). I guess it doesn't quite seat onto the internal circuit board switch quite right. Yay, working again! Then I got lectured to oil it once a month or every bin full, which I haven't been doing...
9/5/2020 3:36:15 PM •
Fellowes...
Answered
on Sep 05, 2020
Won't turn on...
You don't say what type it is, but they usually have little micro switches fitted to ensure the power won't come on until the blade section is fitting properly to the waste container part.If it is the bucket type with the shred part on top just make sure it rests properly on top of the bucket so the microswitch on the bottom of the shred part gets depressed. If it's a drawer type there may be a small projection on the drawer which pushes against a switch in the body of the shredder.
10/29/2013 12:41:28 PM •
Fellowes...
Answered
on Oct 29, 2013
Why is the fellowes blade still rotating even when
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
Unplug the paper shredder. Empty
the shreds from the collection bin. Pull as much stuck material as
possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
Place the paper shredder back on
the collection bin base and plug the shredder back in. Rock the
shredding direction back and forth between forward and reverse.
3 Make two passes across the
cutting blades while drizzling synthetic shredder oil. Switch the
direction to forward to run continuously for one minute.
Lower two sheets of clean paper
into the shredder. The paper removes excess oil, metal fragments and
debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
9/26/2011 11:09:12 PM •
Fellowes...
Answered
on Sep 26, 2011
Machine over heats and light oil light comes on.
Hi, you can place some oil on a piece of paper that you wish to shred & put that through your shredder. You do not need to saturate the paper, but use enough to lubricate your shredder.
3/17/2011 6:49:43 PM •
Fellowes...
Answered
on Mar 17, 2011
What is the fiscal size of Fellowes shredder?
Question edited for clarity, spelling of 'Fellowes'.
I don't think 'fiscal' means what you think it means?
fis·cal
/?fisk(?)l/
adjective
relating to government revenue, especially taxes.
"monetary and fiscal policy"
Fellows does all sizes of shredders up to Office Quality machines that will also Crosscut shred credit cards and CDs.
https://www.google.com/search?q=Fellowes+shredders
