DO the scanner has wifi? Or an Ethernet port? Setup wifi commnly the setup is when you install the product so insert the cd and follow.But if the scannner has no port or wifi you can not do it.
Hello Ronald Ware, Welcome, and thank you for using FixYa! To answer your question: There may be a worn out feed tire, separation pad, or even a broken sensor causing this issue. The unfortunate solution to this issue though, in my opinion, is to take this unit to a local Office Repair or Computer Repair Center to have these parts examined and replaced, as necessary.I would normally perform this service for roughly $60.00 to $80.00 plus parts. Have a great day!
Tthe Capshare only works with XP or Windows 7 Ultimate which has a virtual XP inside it ( a retrofit for outdated software).. I will not work with VIsta.
Here is your network guide for the 5200n printer If you do not have the 5200n printer, it is not network. You will need a 'print server' ($100 approx). Get USB or Parallel, depending on the connection it uses.
If you have built in 10/100 RJ45 then any network connection is possible.
One to one, you can connect to any built in 10/100 RJ45 equipped computer with a 'cross-over' network cable.
More commonly you can connect to a 'router' which allows a number of computers to connect to each other and to the internet . Use a search engine to find net setup on the 'web. This is a very large subject so you need to decide what you want to do first!
See http://www.computerhope.com/issues/ch000469.htm#04 or http://compnetworking.about.com/cs/lanvlanwan/g/bldef_lan.htm or even http://www.microsoft.com/windowsxp/using/networking/setup/default.mspx
