20 Most Recent HP Pavilion Media Center TV Desktop with AMD Phenom Processor 9500 Questions & Answers
if the 512mb nVidia is PCI-express then it is compatible. the point here the slot. if the slot is PCIE then the card should be PCIE also
HP Pavilion... | Answered on Jun 20, 2011
Your title says you have an AMD CPU but your text says you have an Intel CPU. Which is it?
HP Pavilion... | Answered on Dec 17, 2010
If you have built in 10/100 RJ45 then any network connection is possible.
One to one, you can connect to any built in 10/100 RJ45 equipped computer with a 'cross-over' network cable.
More commonly you can connect to a 'router' which allows a number of computers to connect to each other and to the internet . Use a search engine to find net setup on the 'web.
This is a very large subject so you need to decide what you want to do first!
See
http://www.computerhope.com/issues/ch000469.htm#04
or
http://compnetworking.about.com/cs/lanvlanwan/g/bldef_lan.htm
or even
http://www.microsoft.com/windowsxp/using/networking/setup/default.mspx
HP Pavilion... | Answered on Sep 13, 2009
Something's gliched, and the only thing I can think of is to run 'msconfig' and remove the PA from the startup programs.
HP Pavilion... | Answered on Apr 30, 2009
This could be for numerous reasons
1. the disc is not compatable with your drive ie its a cheap branded one so get a decent branded spindle of discs ie TDK or tayo yuden or the likes
2. The disc is blank
3. Is this only with blank dvds ( dvd-r, dvd+r, dvd-rw, dvd+rw ) ?
4, can you play or read normal cd's just not dvd's ?
I had a similiar problem when my old dvd rom drive was getting old and sometimes it would work and others it wouldnt the only other thing I can think of is to ensure the chipset drivers ie the IDE / sata drivers are up to date and also are there any firmware updates for the dvd drive ?
Also ensure if there are any jumper pins ensure they are set correctly and that the data cable and power cables are seated firmly as per the other suggestion.
WIth the prices of dvd drives now it would be easier to buy a new one and replace it.
HP Pavilion... | Answered on Apr 10, 2009
If you stick an audio CD in the drive will it play? If so then the OS can read the drive, if not the drive could be dirty or just defective. Also, Windows XP will not burn DVDs natively, I recommend downloading this software http://cdburnerxp.se/.
HP Pavilion... | Answered on Apr 09, 2009
most likely it was the psu. You can actually test it yourself by buying a psu tester made by Antec that you should be able to buy in stores. It's a cheaper alternative to buying a PSU and just hoping that was the problem.
HP Pavilion... | Answered on Jun 20, 2008
Hi, You said ALL your games are choppy ....Conan is a demanding game ..
Example:
I have seen it run on a MSI board with 2 Gs of PC6400 (800mhz) / AM2 4800 X2 (2.5Ghz) with an AGP!!! GS7800 Nvidea video card (which was a good card in its day...42Ghz bandwidth) ...it ran at about 30fps on Medium settings which is livable???...
The first thing to do is to make sure you have all the latest drivers for your Motherboard from HP (made by Asus for HP )
also make sure Windows OS it self is all up to date ....
The video card is 8800 Nvidea ? which one?
Go to the Nvidea and get the lastest drivers for it ...this is MOST IMPORTANT ...
You also have onboard Graphics card 6150 ...go to Device Manager and see what is listed....To access Device Manger Go to ....Start>Control panel > Systems ( maintenance) and select Device Manager....click the + sign next to Display adapters and if the (6150 onboard graphics adapter) is listed with the 8800 right click on the "6150 " choose Properties and make sure it says..... ( do not use (disable) under .".Device usage."....
....Apparently these can run concurrently
HP says PC6400 Ram (800 mhz) will run on this board.....a PRICEY option of course
NOTE: All RAM isn't created equal it is best to use a Quality RAM from the SAME manufacturer //try not to mix n match
Lastly there's the Power Supply ...the new Video card will draw more power ....a good 500 plus watt PS with good Amps well
across the Voltage rails 3/5/12 .....25A plus is a good target
Again more money :)
Also turn OFF Programs while gaming I do no matter how fast the Rig is .... ie Antivirus...etc..... every little bit helps
Do the Driver updates and see what happens ...Good Luck
HP Pavilion... | Answered on May 31, 2008
This combo should play games no problem ....more specs please...like what Motherboard /ram speed and such
HP Pavilion... | Answered on May 28, 2008
What is the Name and model number of your motherboard
The nforce 430 is an older chipset model and may not use the full capacity of the Phenom processor ...some boards won't even boot and there are Bios updates available for others ...etc
The onboard graphics (geforce 6150 se) is negated by the 8800 GTX ...good card......the problem isn't your video card
Your also running PC5300 ,,667mhz ram ....if board is capable of PC6400 ...800mhz ....there could be another speedup
The bottlenck seems to be with the board and possibly Ram
(Again MB model and name)
Also make sure you have all the latest drivers for Vcards ...chipsets BIOS etc......
The 0xc0000185 error simply means that the computer can't communicate with the CD drive. It could be due to a faulty CD drive or media, a bad connection, faulty interface, bad memory, power supply etc. You will need to isolate the problem further, why couldn't you boot normally? check the BIOS settings again and try clearing the CMOS memory correctly as described in the manual (just removing the battery may not be good enough).
HP Pavilion... | Answered 2 days ago
in your android phone's settings enable or access developer options and turn on usb debugging,( if you don't know how to access developer options you can google your android phones model and android version and how to enable usb debugging) once you enable it just plug it into your laptop and it should recognize it and automatically download the correct driver, if not, go to your phones manufacture's website and look for driver downloads for your model and android version. you can also google this to save time.
HP Pavilion... | Answered on Dec 31, 2019
A DVD player that is an integral part of the laptop does not need drivers to make it play discs. If there is no driver shown, maybe the DVD unit is faulty?
All laptops will play CD/DVD from boot without drivers. The drivers are there to allow you to do specifics to the DVDs.
HP Pavilion... | Answered on Dec 16, 2019
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
To fix 0x80070057 errors you need to follow the steps given below:
Update Windows driver:
An obsolete driver can be one reason for causing this error problem.
Therefore to remove 0x80070057 errors message from your system you need to update your Windows driver.
For that you must
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html also
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
Registry repair: Corruption to the registry can cause 0x80070057 errors to appear. Registry is the storehouse of files and program settings. Therefore frequent access to the registry key can cause corruption to it. Therefore you need to to repair the
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
registry. also http://download.cnet.com/ccleaner/
If the error problem still remains in your system then it is recommended to
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
It might be possible that due to virus or malware has infected your system that's causing 0x80070057 errors.
The anti spyware software will remove the viruses and make your system clean.
Hence increases the performance level of your system.
all of this is freeware
hope this helps
if there are any stubborn drivers
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
HP Pavilion... | Answered on Jul 31, 2019
you can try going into your control panel and look for the speaker icon click in there and you should be able to set your sound settings.
HP Pavilion... | Answered on Jul 15, 2019
I am assuming you are wanting install this on a HP machine, so all you should need to do, is go to the HP website if you use the machine you want to install it on, the web site should be able to detect, your make and model, and if any software is missing it will direct you to the page where you can download the software, and install it in the same way you install any other application in windows.
HP Pavilion... | Answered on Jun 12, 2019
which email service you use go to it
type in your ID name & in the same menu box
look for CAN'T LOGIN TO MY ACCOUNT
and follow the prompts
HP Pavilion... | Answered on Feb 12, 2019
old post, I do only 2018 posts)
first off why the huge contradiction even HP and ASUS mixed.
photo of laptop, and title, NOTEBOOK
and texting a Desktop, but must be a so i moved you....
p6126f PAVILION. it is. no monitor stated, at all. no errors show on monitor, like no signal?
the PC blue light means it thinks its one.
the fans must blow, both PSU and CPU or you have no 12vdc power.
the uSB ports have power, but that happens even with PC in standby mode, or even turned off, that is how I charge my cell phone PC off, using my USB ports,
what matters is:
1: monitor errors, seen
2: Fans.
3; you clicked shut down via what< windows, linux what?
if you CLICKED shut down and the fans don't go dead
that means your OS is corrupted. for sure.
top reasons are bad drivers, and vista can't shut down.
or worse. there is always that. (virus)
I'd DUMP vista, nobody on earth wants to help anyone with a dead vista , horrid VISTA, did you know MS in there great wisdom failed to add recovery mode to vista, yah sux, swap gas. that.
upgrade to w7 and end this silly mess called vista.
w7-64bit is best here, with full HP support seen here.
this is not spam, its the real HP, the place with no malware,etc.
https://support.hp.com/us-en/product/hp-pavilion-p6100-desktop-pc-series/3942799/model/3999655/product-info
HP Pavilion... | Answered on Dec 11, 2018
Take it back to the retailer. Unless it is more than a year old. The graphics chip or screen has failed.
This error comes up if you have replaced the branded drive with an oem one, the original drive is watermarked and the OEM one is not, the restore disks look for this watermark, and will not install if it cannot find it, it then gives you the error above
Cliff
OEM
HP Pavilion Media Center TV Desktop with AMD Phenom Processor 9500 Logo
11 questions posted
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
hp media centre m1180n wont power up
  • Computers & Internet
