20 Most Recent
HP Hewlett Packard LaserJet 5200 Printer Questions & Answers
41.2 error hp laserjet 5200
41.2 error hp laser jet 5100
am from Ethiopia but when am check and replace the Formatter board ,beam not working but when am replacing the DC controller and all connecting cables to beam, then it was working god .
10.10.00 supply memory error coming on HP Laserjet 5200 Printer.
Dear Sir,
I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
Thanking
Ajom Khan Hero
Mobil No.092 5192797.
Al Nahr Co.Ltd
Tripoli - Libya
Hp laserjet 5200
firstly check whether the problem is internal or external-
Have the printer print out the config page- if you can see the image then the issue is external to the printer- check your PC settings
If you cant see an image-
You say you have allready changed the toner unit, was this before the fault or after?
under where the drum/toner cartridge sits there should be a Black 'transfer' roller that will line up with the drum surface when inserted- if this is missing or failed then the image cannot be ' transferred' from the drum to the paper. this is just one possibility, if your not sure wheher the transfer roller is working - stop a print half way through- remove the paper and toner unit - slide the drum surface protector to the side and look at the drum surface for a latent reversed image in toner on the surface of the drum, if you can see an image the problem lies with the transfer element, if you cant see an image then it could possibly be the charge chorona/ HVT PWB / Laser unit, main Pca, power supply hope this helps
I have a HP 4250
Just press the checkmark, that will set the printer to ready state
Printer is not readyness due
The rear door is open (after creating a cleaning page). Close the rear door (at the back of the printer).
Good Luck!
Hope this helps!
CreativeTECH
Hplaserjet5200
Our Address is
KENDRIYA VIDYALAYA OEF
Opp New Taxi Stand
Shukla Ganj Road
Kanpur
05122330397
9415731684 Sandeep Sinha
Hp5200
how to open the printer
WEEK PRINTING
Shake the catridge and reload it , if still the print quality is bad in crese the resolution to 600dpi in the printer setup.
