20 Most Recent Sabrent USB 2.0 NT-USB20 Ethernet Adapter Questions & Answers
have a try in maplins see if they can help thats where i went
Sabrent USB 2.0... | Answered on Sep 26, 2013
for your download click htt
This device will work on win7, no problem. You'll need the install disc or the software.
UM100 win7 64bit
1.Double-click the quicklinkmobile.exe application from cricket. It will unpack a folder with the installation files in the same folder the quicklinkmobile.exe app is residing.
2.Go in that folder and click on start.exe, then click on install quick link mobile. Go through the normal setup as you normally would.
3.Once it finishes installing, connect your UM100 UTStarcom modem on a free USB Port. Don't open the Cricket Wireless application just yet.
4. Go to start menu, right click on Computer and select properties. Then click on device manager on the left. You will find the UM100 modem has an exclamation point on it.
5.Right click it and select update driver. Select "Browse mycomputer for driver" Option at the bottom. Click on Browse to select a driver from a location, then navigate to your root drive (usually C: and sometimes D then to Program Files (x86)/Cricket/Quick Link Mobile/System
6.Make sure you navigate to this cricket wireless installation folder. It should be in C:\Program Files (x86)\Cricket\QuickLink Mobile\System. Once you find it click ok. Make sure "Include subfolders" is selected under it. Click on "next" and now it will install the driver.
7. After it installs, it will create two more Unknown devices with exclamation points. Wait a couple of minutes for the system to finish up installing that one before you continue with this instructions.
8. Now repeat steps 5 and 6 above for each of the two unknown devices until there are no more devices with exclamation points in device manager.
9. Now open Up Cricket Wireless application on your desktop or start menu, and continue with the normal modem activation of the wizard that appears. That's it! It will now detect the modem and activate it. Allowing you to use it.
10. Go and find whoever said you couldn't use this modem on 64-bit systems and punch them in the face.
11. Call me so I can punch them in the face again.
12. Enjoy your newly installed UTStarcom UM100 cricket modem on your 64 bit system. Ask Cricket to update their website with this information. Punch them in the face too for the sake of completeness
Read more: http://www.cricketusers.com/cricket-mobile-broadband-devices/20339-utstarcom-um100c.html#ixzz22FHP7OMr
hope this helps
Sabrent USB 2.0... | Answered on Jul 31, 2012
This is a LAN device that is used for network connection and Internet connection to a cable or DSL modem.
Sabrent USB 2.0... | Answered on Apr 12, 2011
usb female to rj45 adopter
Sabrent USB 2.0... | Answered on Jul 16, 2010
You should find the manual that comes with the Router. It will have good instructions on the details to configure this.
Basically you will use your browser on your desktop to connect to a web page within your nb504 router.
You will turn on wireless connections and enable security plus give your wireless network a name.
Once that is done you will configure security on your laptop to connect to your wireless network.
Don't skip the security bit or your neighbors will be able to use your internet connection for free.
The default settings in modem devices are really good these days so follow the recommendations in your router manual and you should be able to figure it out.
If you can't find your router manual you should be able to download it from Netcomm.
Hope this helps
Sabrent USB 2.0... | Answered on Jul 12, 2009
you need to call the co. that made the device and software to gain a software key to install the device.
Sabrent USB 2.0... | Answered on Jun 27, 2009
Im not aware of any gadgets, but you can always use the USB stick on one laptop, share the internet connection, and connect the other laptop throught the shared connection.
That would require your laptops to be networked, either by a crossed cat cable or with regular switching or routing.
Sabrent USB 2.0... | Answered on Feb 03, 2009
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
PC1:
IP: 192.168.0.2
Network mask:255.255.255.0
PC2:
IP: 192.168.0.3
Network mask: 255.255.255.0
Default gateway: 192.168.0.2
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Regards
Imre
Sabrent USB 2.0... | Answered on Nov 26, 2008
yes, photos 101
I can answer most questions if the level.
first off no photo editor does all formats of all camera's made.
that is a fact. some come close with $300 software. you don't have.
my guess is your camera uses the great TIFF format.
no PC STATED, NOR OS VERSION, SO I CAN KNOW WHAT
VERSION OF PAINT YOU HAVE.
Windows 10 paint does tiff,giff,jpg and even bmp so it's not that.
first off when moving photos off any camera made.
look to see what the file names are the extensions.
dm0101.tiff is TIFF.
dm0101.bmp is BMP.
see, ?
the see if it is too big, many editors of photo can not do 50foot wide photos as some pro camera's can do. (CANON top brand)or NIKON.
the camera has settings mode, set it to JPG or PNG mode
and any editor can edit those.
sabrent product
my wild wild guess, next this name above is 3.5" extrernal USB flopy diskette reader
that say your relic 2000 year, SONY 3.5" camera created .
(yes they did that back in the day, )
and now you connect the 3.5" Sabrent and you can copy said
fails ok, but failed to note the full file names.
to see extensions you must tell nasty windows you want to.
yes windows is PAIN, in this one regard.
so you go to control panel.
click file explorer options.
then click VIEWS TAB.
then click and uncheck hide file exemptions. (leave OS extensions alone below)
after doing this great act (we do this step one new PC or OS)
we can see what kind of photo is for the first time.
then post that and we can edit anything
or get GIMP, for free for windows.
Sabrent... | Answered on Apr 15, 2019
go to contol panel, devices and find sound,look for the drivers for this,Sabrent and remove them and reinstall them...which probably means downloading the from Sabrent web site unless you have a disc
Sabrent... | Answered on Sep 30, 2018
Plug it into a USB port and it should be seen by Explorer and listed as an external drive.
Sabrent... | Answered on Jan 25, 2018
Not knowing which product you need a driver for, I recommend going to there website and click on support;
https://www.sabrent.com/support/
this will assist you with most questions you have.
Sabrent... | Answered on Nov 07, 2017
Sabrent USB 2.0 NT-USB20 Ethernet Adapter Logo
Popular Tags
21 questions posted
Top Sabrent Computers & Internet Experts
Colin Stickland
Colin Stickland
ChinthakaJ
ChinthakaJ
Joel Rodriguez
Joel Rodriguez
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sabrent Computers & Internet
Most Popular Question
wiring diagram converter from usb
  • Computers & Internet
