WARNING RIBBON IN IS SHOWING UP AND WE DO NOT USE THE RIBBON CAN SOMEONE HELP
The media could possibly be loaded incorrectly, making the printer think the ribbon is loaded. The sensor is on the inboard side. There is a metal plate with two resistors on it. The labels need to be loaded under this plate.
The printer is set to Thermal Transfer mode (uses a ribbon). You need to set it to Direct Transfer mode, so that no ribbon is expected. You can do this in the control panel on the printer. Must also do this in Windows, in the properties of the printer (Control Panel-> Printers.)
Good luck.
Malcolm
