20 Most Recent Zebra 170XiIIIPlus Thermal Label Printer Questions & Answers
2answers
Clear print job on Zebra printer
Simply press the PAUSE button then press CANCEL. If you have sent a batch of 500 labels, though, you will have to press CANCEL 500 times. I usually just turn the printer off, cancel the job in the printer driver status box, then wait for all of the error messages to pop up.
1/12/2021 4:48:04 PM • Zebra... • Answered on Jan 12, 2021
I have a Zebra 170xiIII. The feed motor runs both forward and backward. Will be running fine and I have to pause and will start running backward. Have replaced motor and same thing. What's wrong?
The DC power supply drives that motor and may start running it backwards when it begins to fail. The motor normally makes more noise than usual in both directions when it starts to fail like this. Google "43470-002 power supply, Xi III +" and you will be able to purchase the part.
4/3/2015 1:48:31 PM • Zebra... • Answered on Apr 03, 2015
2answers
Hello, Our company is using a Zebra 170XiIII plus
I believe you should check the website and download the manual and go over. I think you will find it useful.http://www.zebra.com/id/zebra/na/en/index/products/printers/high_performance/170xiiiiplus.html
6/21/2014 6:18:51 AM • Zebra... • Answered on Jun 21, 2014
ZEBRA S4M00 - 200E - 0100T printing text at 0 degree direction and 180 degree rotate direction
you possible can with software, (easylabel or Bartender)
6/1/2014 2:40:12 AM • Zebra... • Answered on Jun 01, 2014
I have a Zebra 170xiIII Plus (200 dpi) that keeps
Easy, your print job has PR (Print Rate) code set on the zpl code in the job file sent.remove the PR code and you are done!
10/21/2013 9:55:37 AM • Zebra... • Answered on Oct 21, 2013
0answers
Paper out error
Have you tried a full media calibration from the menu (removing 8" of label from the backing)? Also if a label has left any pieces behind on the rollers, strike plate, etc it can cause this problem. I use a solvent like Goo Gone to make it clean, but be careful not to wipe the sensors with it. Also I have seen this when my users miss a roller when loading the ribbon. Make it clean, load it carefully and usually it works.
10/12/2012 4:58:08 PM • Zebra... • Answered on Oct 12, 2012
0answers
I am having trouble in
Make sure you are using the correct driver 170xiIII plus, and make sure the dpi of the driver matches the print head resolution.203 or 300dpi.
9/23/2011 1:47:20 AM • Zebra... • Answered on Sep 23, 2011
Label size
Do a calibrate on the panel. you have change your label length
9/16/2011 12:37:08 PM • Zebra... • Answered on Sep 16, 2011
How do I put in an ip address in a 170xiIII plus
You should be able to get to the setting by pressing the SETUP key and then press NEXT until you see a setting called IP RESOLUTION. Use the black oval keys to select Dynamic,Permanent. The default password is 1234. Use the left black oval key to change number position and the right one to change the number value to set the password, then press NEXT. Press NEXT until you get to IP ADDRESS. Again, use the left black oval key to change number position and the right one to change the number value until you get the desired IP address. Press SETUP again and then press SAVE to make a permanent save.
This assumes that you have an internal ethernet card installed.
Hope that helps.
8/14/2011 2:38:35 PM • Zebra... • Answered on Aug 14, 2011
How do i getpage counts off these printers?
Access the printers web page. (- Type its ip address into a computer that can route to it.)
It is on the bottom of the View Printer Configuration Page
4/1/2011 10:13:06 AM • Zebra... • Answered on Apr 01, 2011
We are using the Zebra
Make sure the pause light is on and press calibrate. See if this calibration solves the problem. If not align the media sensors (top and bottom) to a position that is aligned with the least amount of preprinted data and calibrate again. Print configuration Power on while holding cancel key for 10 seconds. Use the config to help troubleshoot. Make sure the sensor type matches the media. Download user manual at zebra.com.
11/21/2010 2:26:13 PM • Zebra... • Answered on Nov 21, 2010
Have a Zebra 170XiIII Plus that goes straight to
press PAUSE and CANCEL to reset the printer. turn off and on again.
11/15/2010 3:13:48 PM • Zebra... • Answered on Nov 15, 2010
How can I rotate a graphic? we have a logo which
try to go to the driver and go to Advance Setup, here you can rotate or reverse the image.
11/13/2010 10:38:39 AM • Zebra... • Answered on Nov 13, 2010
Zebra 170XiIIIPlus Thermal Label Printer Logo
Popular Tags
42 questions posted
Top Zebra Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Mike
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Zebra Office Equipment & Supplies
Most Popular Question
zebra 170xiiii feed motor runs both
  • Office Equipment & Supplies
