I have a JVC HR-J610U VHS VCR and i cannot set the tracking. please help. I have the original remote too but it does not have a tracking setting on it.
2879,2860,2899,2858. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/
Try website like Remotes.com to buy the VCR original remote.This site sell all DVD/VCR,DVD, VCR,TV and all electronics original and clone compatible remotes.
the eject button is a plastic piece that turns and pushes down on the board and is more then likely broken open the vcr take off the front face plate and check the button, it will propaply fall out. you can use super glue and glue the button back in place
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Not all tracking is created equal, and this is a classic example of what you want to do in the future. Make sure that the tape you want to play back in the secondary machine has been recorded originally in the "SP" mode. "EP mode sometimes has too much crosstalk to effectively play in other machines without the more closely spaced tracks interferring with each other. Hop this helps...Accordianman
you must select the input in your vhs. usually its a line input (wether 1 or 2). try to find it also using your supplied remote for the vhs. good luck!
