Need diagram to how the belt goes on and how to adjust the tension on the belt
SOURCE: washer belt
To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
SOURCE: AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
MOdle NAH6800 I beleive its either 2 or 3 years old. I have water in the outer tub. I can hear it when I turn the tub is this normal
SOURCE: Need diagram showing Amana ALW880QAW belt replacement.
This doesn't explain how but it may help anyway. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ALW880QAW&productCategoryId=0153200&brandId=1268&modelName=AMANA-LAUNDRY&diagramPageId=00005&componentDescription=MOTOR,%20PUMP,%20BELT%20&%20IDLER&documentId=M0512380&backToLink=Return%20to%20Sub%20Components%20list
SOURCE: I need a visual picture of the belt assembly for my washer
belt routings
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: diagram of installing belt on amana washer
show diagram on how to install a belt for Amana washer model number ALW410DAW Serrial number 0006303339
