Question about Amana Washing Machines
Lid lock button keeps flashing and wont engage need to bypass so the washer will run
ITS A SAFETY PRECAUTION SO SHOULD NOT BE BYPASSED BUT SEE PICS ON HOW TO BYPASS
Posted on Feb 11, 2017
SOURCE: replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Posted on Apr 15, 2007
SOURCE: Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Posted on Jun 25, 2008
SOURCE: need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Posted on Oct 08, 2008
SOURCE: How to bypass Lid Switch Admiral Washer
The only way to bypass this switch is fist pill the plug, gain access to the switch from under the hood. put a jumper wire on the 2 wires on the switch. that will do it. I hope this helps you out.
Posted on Nov 28, 2008
SOURCE: Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Posted on Jun 20, 2009
Aug 31, 2016 | Washing Machines
Jan 03, 2016 | Maytag Washing Machines
Nov 26, 2015 | Washing Machines
Oct 12, 2015 | Washing Machines
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Mar 30, 2014 | Maytag Bravos Top Load Washer
Feb 11, 2013 | Maytag Bravos Top Load Washer
Jan 08, 2013 | Maytag Bravos MTW6600T Top Load Washer
Dec 28, 2012 | Washing Machines
Nov 04, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
9,179 people viewed this question
