20 Most Recent Amana NDE2335AY Electric Dryer Questions & Answers
http://shop.ebay.com/i.html?_nkw=amana+pulley+&_cqr=true&_nkwusc=amanna+pulley&_sop=16&_rdc=1
Amana NDE2335AY... | Answered on Jun 07, 2015
Good Afternoon,
Unless there is something restricting the ventilation I think you are having a problem with the heating coil staying on too long. If that is the case, one or more heating sensors are bad. Let me know if this helps and thank you for using FixYa!
Amana NDE2335AY... | Answered on Dec 15, 2014
Most likely you have to disassemble the dryer and vent and may be drum
Amana NDE2335AY... | Answered on Dec 06, 2013
Can you spin the drum by hand?
Amana NDE2335AY... | Answered on Nov 27, 2012
There is power there, it is just that the circuit board that is on the control panel is defetive.
Amana NDE2335AY... | Answered on Feb 01, 2012
A thermal fuse blows (opens) when the temperature is above the set value. When is blows it will have to be replaced before the circuit is operational again.
A thermal switch deactivates the circuit until the preset temperature is reached or deactivates a circuit that is too hot.
Amana NDE2335AY... | Answered on Dec 15, 2011
Hello.
This link is a diagram of how the belt fits onto the motor/tensioner pulley...for your brand it is diagram A http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramA
GENE
Amana NDE2335AY... | Answered on Oct 21, 2011
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Amana NDE2335AY... | Answered on Sep 11, 2011
Unplug it
8_17_2011_6_59_49_pm.jpgget the front off and you will see this
8_17_2011_7_02_19_pm.jpg8_17_2011_7_02_40_pm.jpgYou will be able to access and clean out that blower only if you remove the front. You cannot work from the back side of this machine
Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Amana NDE2335AY... | Answered on Aug 17, 2011
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Amana NDE2335AY... | Answered on Aug 13, 2011
hello dischukker, you've got one or two problems; or both.
The first thing to do is check the nylon or plastic guides at the front of the clothes drum for support.
I'm posting a video right after this sentence that shows the glides on a diagram as well as ordering information and pricing. What I loved about this site is they actually have a video right below that shows you how to install them. What a deal, right? When these become worn, they can make a lot of noise. They look like big white breath strips, and they're super easy to remove and install. You will know by looking at them, if they're worn. trust me.
http://www.partselect.com/PS2039613-Whirlpool-37001298-Dryer-Drum-Glide.htm?SourceCode=5&ModelNum=nde2335ay
The next thing to check would be the thrust washer. And like the other one, you will see the part in the link, and a video of how to install it.
http://www.partselect.com/PS333174-Whirlpool-233520-Thrust-Washer.htm?SourceCode=5&ModelNum=nde2335ay
This should take care of your noisy dryer. I hope you found this information helpful. I will be happy to assist you further if you need any more help.
thanks,
Mike
Amana NDE2335AY... | Answered on Jul 22, 2011
Hi finer5...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley, or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Amana NDE2335AY... | Answered on Jun 29, 2011
Hi finer5...
Amana NDE2335AY... | Answered on Jun 27, 2011
Amana NDE2335AY Electric Dryer Logo
112 questions posted
Top Amana Dryers Experts
Marvin
Marvin
jdthefixer
Are you an Amana Dryer Expert? Answer questions, earn points and help others
View Most Popular
Amana Dryers
  • Amana Dryers
Most Popular Question
squeaky dryer
  • Dryers
