Server is not visible on the network and won't connect to HTTP. It's a configuration issue so the hardware is fine. Additional info: OS is Windows NT
SOURCE: Dell poweredge start up issue
Hi. If your server is not responding at all when you want to power it up, you need to replace the power supply. If it starts up then shutdown it could be a motherboard problem but the most probable thing is that your power supply needs to be replaced. If you have an other one with about the same power, try it and see what happens. Good luck!
SOURCE: PowerEdge 1800 Server: I have a Dell power edge 1800 that was used as a s...
yes you can do that but you need the drivers for the scsi interface. when you install windows xp (for example) i think you may have to press the f6 key on the installation to add these drivers.
Otherwise, installation wont take place.
Upon closer inspection there is no SCSI device found. This is the problem I'm sure because the conifguration is fine. I'm sure. What do I do next?
