20 Most Recent
Dell POWEREDGE R710 E5520 226G 2P 4GB 2X2GB UDIMM 160GB SATA 2U (4685703) Server Questions & Answers
Installing Dell PowerEdge R710 DVR Server
- VIA a serial cable (looks like monitor cable is not). You have use something like telnet. Old school and very technical.
- Just connect a monitor, keyboard, and mouse and treat like a regular PC. Can't go wrong.
I am needing to know
The device you have can take 6 hard discs there can all be internal. You should not need to do much other than plug them in can configure them for use, so your question confuses me, can you provide some further information please.
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
STRIKE f1 ERROR
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Format disk
what is your server model? in most cases you can use the operating disc to format the server drives
Serial number CDB6HJ1
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
Dell Poweredge 2900 I912 SEL FULL
Best is to find a support or systems engineer on http://www.qual.ch if you are in Switzerland and for the UK you can find find a top Dell expert or systems specialist on http://qualifind.co.uk -- I just asked one (from Qualifind) and was informed you just need to install Openmanage and clear the logs from there, no need to down the server.
