Setup router without problem. Status showing it has picked up the correct IP Address, DHCP, DNS settings. Workstation picks up 192.168... address. Cannot connect to Internet although can connect to some URLs which are cached.
Very, very slow connecting to router interface.
Any ideas??????????
SOURCE: cisco asa5505 problem
You seem to have the last resort (o.o.o.o) set to VLAN1 which is set as an inside interface.
Is VLAN1 connected to the outside router or internet backbone?
If not, change the last resort to the outside Ethernet port.
SOURCE: interface will not come up to configure router
Use pin-hole to reset router. Try default 192.168.1.1
SOURCE: router gets disconnected
If you know how to open the setup page of the router, look for MTU. Normally it is set to Auto with default size of 1500. Now set it to manual and change the value to 1463 and save the changes. Power cycle the router by unplugging the power for 30 seconds then plug it back in. Observe your connection if it keeps on dropping.
Another is you need to isolate the problem if its the router or the modem. Try to connect your PC directly to your modem and observe if it does the same thing. If it does the same problem, call your Internet Provider to fix the modem.
If the problem still persist on the router after changing the MTU, try to update the Firmware of the router and hard reset it by pressing the reset button for 15 seconds then power cycle it.
SOURCE: cisco 871w router
Is this router brand new sound like it could be a bad router. The wan port could be going bad. I have had similar problem like this before and took days for me to figure out.
SOURCE: Sending DHCP request across diffrent vlans
Hmm... on your DHCP server, try setting the "default router" IP for each pool to be the VLAN ID on the switch.
scope 172.16.0.0 /24
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
I think the DHCP replies aren't going back where they should. I've never done this without a router doing all the DHCP, but it does work and i've done it many times. Your config looks spot on for the switch.
