Compex NetPassage 28G Wireless Router (NP28G) Logo
Posted on May 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connecting Compex 28g to mobile broadband and home network
The remote computer says it is connected but Internet Explorer says no.
Sanjay Ghosh
Level 2:
  • Expert 67 Answers
  • Posted on May 01, 2009
Sanjay Ghosh
Expert
Level 2:
Answers
67
Questions
0
Helped
13140
Points
207
Please check following points:-
1) IP address (some wireless AP's follows ip address such as 192.168.1.1 for AP and 192.168.1.2 for 1st workstation, 192.168.1.3 for 2nd workstation and so on).
2) check connection options in IE. it should be lan setting and detect automatic setting and use automatic configuration script(put IP address of AP)
3) if DHCP is enabled then obtain IP automaticlly
4) check for any WEP security options i AP.
5) user must have internet access rights.
6) if Static IP is Used please give gatway ip (your AP's IP address) and same for DNS IP address.
then restart your system and enjoy internet.
Have contacted bt but no known problems or work going on in area. Cannot get on demand and cannot get internet access on home laptop but can get access on king del fire, mobiles and Iiphone. Postcode cm12...
Mobile units are probably connected to the cell data network. Is the router connecting to a broadband modem? If so, unplug the router and plug your laptop into the modem. If your laptop doesn't have a RJ45 connector find a computer that does and plug it into the modem. If you still can't access the internet the modem is probably bad.
tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 • Computers & Internet
tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 • Computers & Internet
Connecting to the internet
SETTING UP A INTERNET BROADBAND CONNECTION
First you need to decide what type of broadband and Internet service you require and these are -
1. DSL that uses your existing telephone line.
2. Cable that uses a cable service and can include a cable TV service.
3. A wireless 3G network uses the mobile/cell phone network and can be separate or combine with your cell phone account. This type of Internet connection uses an USB wireless device shaped like an USB memory stick.
Note - Combined services generally offer discount pricing and may include a modem/wireless router.
If you use a wireless router with the DSL or Cable Internet service then your laptop with a wireless card can then connect to the Internet. You can also connect to a free WiFi hot spots like McDonalds, Star Bucks, the Airport etc. using the wireless card in your laptop.
If you use the wireless 3G wireless broadband service, then you can access the Internet anywhere where your ISP has 3G wireless coverage. You need to check the service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to check with the various Internet Service providers to see if they can offer and the cost of the various plans.
Note the download limits and the associated additional costs if you exceed the monthly download limits. Once you sign up with a Internet Service provider, their documentation will include setting up instructions and/or installation CD.
1helpful
Wifi keeps disconnecting for no reason
While wireless Internet technology allows us greater mobility in the home and around town, you may also encounter issues with getting a good signal. This common problem has a variety of origins and also depends on your connection method.
Terminology
"Wireless Internet" can refer to two different things: a person using a laptop modem card to communicate over a cell phone network, or an environment where the computers are connecting wirelessly to a nearby high-speed modem. b> Laptop Broadband Networking The user with the laptop modem card can resolve the issue the same way a cell phone user does, since they are connecting to a cell phone network: Find a location where you can get stronger signal strength. b> Mobilizing for Signal Strength b> Terrain can block the laptop user from "seeing" a nearby cell tower, and buildings in an urban environment, like at a coffee shop or at an airport, can cause the same problem. In both cases, seeking higher ground or more a more open area can improve your signal. b> Home Wireless b> In the home, Wi-Fi access is at its strongest when there is not a wall or floor between you and your modem. Sometimes a microwave or cordless phone will also interfere with the signal. b> Drivers and Viruses b> Updating your drivers--packages of software that your computer uses to recognize its hardware--can solve performance glitches. You can also use an anti-virus program to scan for malicious programs that could be interfering. Hope this helps.
tip
HOW TO SET UP SPEED TOUCH 5X6V6 BROADBAND MODEM
Once you have an Internet Service Provider ,ISP,
you just need a modem and phone line access,
plug modem into phone socket and then into the computer,
My example modem is.........
Speed Touch 5x6v6 - Broadband Modem
Operating System is Windows 7
log on to the modem using Internet Explorer Bar
Type 192.168.254
this will open the modems log on menu
then enter user name and password
its factory default is
user ADMIN
password ADMIN or 1234
once open there are some menu options on the main page
Speed Touch,
Broadband Connection,
Toolbox,
Home Network,
to add new user and password,
go to toolbox,
user management,
add new user
add password,(write down username and password)
change default user
save and test
should have a green tick next to new default user now
selecting broadband ... shows both your,
dsl connection and internet connection status,
with a green tick next to each heading.
Home network will show you...
all devices connected to this modems network ie
the other computers and printers etc,
connected on your network.
In network ,select your computer in the menu tree,
select configure
this give you a menu to add info about your computer
ie name info, comupters ip address,
access to the local intranet or the internet
Now lets connect to the internet
select Broadband from front page
menu will open and display
DSL & Internet Connections
here we test internet functionality.on? or off?
Now we go to your computer,
go to start
my network connections
run wizard in my network places
select new connection
follow prompts to the end.
open internet explorer
if web page opens then we are done and finished,
or
open tools and internet options,
connections and then lan settings
select automatically detect
Apply then close
Test webpage again,
when ok shut down and restart,
to save the computers new settings ,
Test again with internet explorrer.
if no connections run wizard again,
Hope this Helps,Cheers Misterdj
on Apr 18, 2010 • Computers & Internet
2answers
I'm trying to connect a remote desktop equipped with Linksys network adapter to internet via a home LAN. Though the network shows that it is connected to the home LAN, when i attempt to connect to...
The setup disc for the router only needs to be run once when setting up the router to work with your internet provider and modem/router. You can try putting the disc in your desktop computer and reconfiguring the router.
My laptop is conecting but says limited or no connectivity but I have a strong wifi signal
Did a bit of research for you on this and came across a ten step set of instructions which should hopefully correct, or at least narrow down your problem:
3answers
Not able to go online
have you been online with this computer before?
or
Are you setting up for the first time?
Type 192.168.254
user ADMIN
Speed Touch,
Toolbox,
Home Network,
go to toolbox,
user management,
add new user
change default user
save and test
select configure
select Broadband from fornt page
here we test functionality.on? or off?
start my network connection
Apply then close
Test webpage again,
Wireless printing
Check the printer's manual if the software of this printer already supports winVista. If it is, you may connect the printer directly to the PC and check if you'll be able to print.
Hope this helps!
Top Compex Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Compex Computer and Internet Expert? Answer questions, earn points and help others
