Folks, these types of severe cartridge
errors (i.e. "refer to documentation" / "incompatible cartridges", etc.)
typically indicate the internal micro-electronics of the HP #60-61 cartridge
are electrically damaged. The cartridge's electrical wire runs at rear and
lower side of the ink cartridge, are very delicate and are somewhat susceptible
to ink attack over time, which can lead to premature failures. In addition, the
older the cartridge the higher the chance of an internal electrical failure due
to prolonged ink exposure and subsequent circuit corrosion. I suggest you
always run a 'Tap 41' diagnostic test to check cartridges electrical health
(this is a forced test); you may also bypass the error (temporarily) on C4600-C4700
models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below: HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors &
Warnings: http://www.youtube.com/watch?v=BskAfa6NJSg HP Photosmart C4600 & C4700 Printers - Diagnostics Tap
41 Test: http://www.youtube.com/watch?v=ghxjLCn07Jo HP Photosmart C4600 C4700 D110a Printers - HP 60 Cartridge
Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg HP Deskjet F2400 F4400 and F4500 Printers - Diagnostics Tap
41 Test: http://www.youtube.com/watch?v=m-OM09NvNqg HP Deskjet 4200 Printers - Diagnostics Tap 41 Test: http://www.youtube.com/watch?v=16uXSBwTan8 HP Deskjet D2500 & D2600 Printer -Tap 10 Diagnostic Test:
Are you sure you are using proper cartridge...
SOURCE: Print Cartridge is Incompatible
Pleas be certain to remove the clear tape from the cartridge before inserting. Check the contact areas in the printer to ensure there is no tape residue or other material in this area. Go to the HP website and follow the troubleshooting instructions for this problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01082138&lc=en&cc=us&dlc=&product=1119266
SOURCE: How do I reset the ink levels on a HP Deskjet
First try the information below
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
SOURCE: I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
SOURCE: hp deskjet f4288 cartridge problem
my printer number is hp deskjet f4288 all in one my problem is my colour catridge haveing ink but but showning error in colour side please send me immediate a solution
