SOURCE: Magellan RoadMate 360
https://www.magellangps.com/support/
select: Product Support & Updates
select your unit and download firmware update for you unit
SOURCE: GPS Magellan RoadMate 360 no sound
http://rapidshare.com/files/96200369/sound.rar.html
Sound files for 360
SOURCE: GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
SOURCE: how do I change the battery in a magellan roadmate
remove the the four screws from the back cover and the back will come off exposing the battery.
careful while removing the cover, the speaker wire is connected to it but you can change the battery with it connected.
chance are its not the battery!
make sure green light is on the car charger and let it plugged in for
awhile, then hold the power button (upto ten seconds) until it
starts..if that fails
the following magellan
2000,2200t,2500,3000,3100,3140,4000,4040 and the 4050 are known to have
faulty dc connectors...if your magellan gps
is not charging or will not power up, its most likely the dc power
port...i sell these power ports and will repair them for anyone thats not
able to do it themselves.
you can get it repaired, or the part here
or buy the port here
if you need further help, just let me know
Testimonial: "Thanks for the help..changed out thr battery...old one was all swollen and seemed close to rupture. Everything is good now...thx."
