20 Most Recent
Magellan RoadMate 1210 Car GPS Receiver Questions & Answers
turn on your 1210 once it boots to the magellan screen press and hold the power button for about 15 seconds, once it shuts off, power it back on by pressing and holding the power button for up to ten seconds then let it load.
if that fails,power it up and try the reset button, (either on the bottom or on the side)the little pinhole, and use a paper clip to depress the reset
button.
bill
Magellan...
Answered
on Mar 18, 2015
Go outside, get a clear view of the sky to acquire a signal. Then try rebooting/reset the unit.
Magellan...
Answered
on Jan 18, 2012
Sounds to me like it's a software update failure. Try reloading the Software Update.
Magellan...
Answered
on Jan 18, 2012
Try checking if the charger is still working. There should be a light on it if it's obtaining power from the lighter port. On some vehicles you need to switch on the car to power up the lighter port. If it's broken, buy a new charger.
Magellan...
Answered
on Jan 18, 2012
Sounds to me like it's a software issue. Let me guess, it says "Unit needs to be restarted to improve performance" then it shuts down and restarts, and cycles again. SOLUTION: Try updating your software, it's free. call magellan tech support, they'll walk you through.
Magellan...
Answered
on Jan 18, 2012
what you can do its update it and it will be faster
Magellan...
Answered
on Aug 19, 2011
It is indicating that you need to connect it to your pc to reinstall the satnav program. You should have a cd that came with it use that to reinstall the software on your roadmate
Magellan...
Answered
on Feb 24, 2011
Right you are. The search feature is only good for the saved or favorite locations. Features on all GPS unites are sadly limited.
There is a program called Street and Maps made by Microsoft what will allow you to search all. Also - you can if search google and then send it to your unit via blue tooth or USB.
Hope this helps
Gary
Magellan...
Answered
on Jun 23, 2010
