Magellan RoadMate 1210 Car GPS Receiver Logo
Posted on Jan 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My gps is stuck on magellan boot up screen. - Magellan RoadMate 1210 Car GPS Receiver
Anonymous
Level 3:
President:
  • Master 1,111 Answers
  • Posted on Jan 02, 2010
Anonymous
Master
Level 3:
President:
Answers
1111
Questions
6
Helped
381773
Points
3221
Turn on your 1210 once it boots to the magellan screen press and hold the power button for about 15 seconds, once it shuts off, power it back on by pressing and holding the power button for up to ten seconds then let it load.
if that fails,power it up and try the reset button, (either on the bottom or on the side)the little pinhole, and use a paper clip to depress the reset
button.
bill
  • src1107 Aug 18, 2011
    there is no reset button on bottom or side so where else could it be?
  • Anonymous Aug 23, 2012
    I have a Roadmate 1200. It boots but says the SD card has been removed
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jan 18, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
12694
Points
8
It might be a software problem or a glitch during the bootup. Try rebooting/resetting the unit by switching off the unit and holding the switch while the gps is off. then switch it back on. If that doesn't work, try using the reset (pinhole).
The software might be also be corrupted, if that's the case, try loading a software update, it's free. you need a USB cable a windows computer and a stable internet connection. You need to charge the GPS too. IF you need assistance in how to do the software update, try calling magellan tech support, they'll walk you through. BTW, I am a Magellan Tech Support Agent
  • Tony Thomas
    Tony Thomas Mar 18, 2015
    Shouldn't a Magellan Tech Support Agent know that you need the unit to boot fully in order to connect to your computer and update?
  • Tom Bondy
    Tom Bondy Jan 08, 2023
    I have the same issue...just about impossible to get tech support from Magellan.....this will be the last purchase from these people!!!!!
3 Related Answers
Anonymous
  • 86 Answers
  • Posted on Jun 23, 2007
SOURCE: magellan roadmate 700 gps not working
Jossie, The cable that connects your hard drive to your main board could be loose. If it's not loose, then it's your hard drive. The only thing you can do (if it's not the cable) is send it in for a new hard drive. Unsure what the costs will be but the magellan logo screen is produced from memory on the main board while anything after that is when the hard drive takes over. -Daniel
Anonymous
  • 10865 Answers
  • Posted on Apr 24, 2010
SOURCE: Glass front broken on Magellan GPS unit. This
Hello. My recommendation is for you to call Magellan directly, get an estimate and then if you choose to, send it in for repair. You may ask a technical support question or request a repair and get a Return Authorization (RA) number by phone. An RA number is required prior to shipping your product to Magellan for repair. Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
Telephone: 800 707 9971 Please rate my answer as very helpful. Thanks, Joe
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Jun 17, 2011
SOURCE: MAGELLAN GPS 1412 STUCK ON
This is normal, this come straight of the satellite. To speed up process or bypass, reboot system. To Manually reboot this model, turn unit off like normal. Then when turning on, keep button down as it fires up, DO NOT release on button, keep it down until all fires up and even about 10 seconds passed, then let go. This reboots it and cleans up a lot of ****. Thanks Mike. Please if this helps, please give me 4 thumbs up, to help me and others. if that dont work, turn it off again fully charge it then reboot it manually again. This should do it!
Frozen screen after update 3.11 to my Roadmate 1470
roadmate 1470 will not boot up. stuck on startup logo
I changed the batteries in my gps magellan 500 and it will not boot up now it gets stuck on first screen what can i do to fix this?
This message is caused by corrupt internal software. In most cases you have to reflash the SDRAM card. Please visit http://www.jungleghost.com/repair_service.shtml as they do this kind of work.
Magellan maestro 3100 stuck at bootup screen
did that just happen all of a sudden or did you try and update the 3100 and it failed to boot after that...if you didnt try to update it...turn the 3100 on then use a paper clip to depress the reset on the left side bottom of the gps and let it restart.
if that fails, let me know and ill help you further
bill
My magellan 3225 turns on, and goes to the system settings page, I cannot get to the main menu. I can go through all of the system settings but that is it
Is your GPS still stuck at the boot screen? Perhaps I can help. Please email me the detailed steps you have taken until you got stuck. My email is kazi at hotmail dot com.
1helpful
Blue screen with magellan logo , this is what I see after turn on my gps receiver, I tryed to push any button but anything change on the screen, to shut it off i have to use 'enter' ,'cancel' and power...
This is the boot screen, Remove the power connection, and reinsert while you press the "Cancel" button at the same time, if done correctly, your Roadmate should continue to boot and enter the user mode.
1helpful
7answers
Magellan Maestro 4250
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
