Using gel packs-- packs remain in dispenser, sometimes breaking open, and sometimes not
SOURCE: The soap does not fully 'dissolve' after running the unit
I believe this is just a matter of dish placement, and not a matter of anything physically wrong with your unit. The way the unit works is when the "computer" tells to open the door, it releases the latch. That is all it is responsible for doing. After that gravity and the splash of the water jets must take over. So simply just make a visual path where you know water jets can hit that area and you should be alright. IF the powered soap is already caked in the dispenser you will have to manually scrape it out with a wood or plastic stick.
SOURCE: my soap dispenser will not open during the wash
There is a quick test to verify there is a problem, this test will take about 2 mins. Open the door, close the dispenser (latched), on the control panel itself, push in this order hi temp wash (HTW) than sani *3 times in that order*. So that means HTW-Sani, HTW-Sani, HTW-Sani. What this will do is run a control service mode, all the LED's will light up, close the door and wait until it stops, within about 45 seconds you should hear the dispenser open. If it opens it is functioning normally, if not, it should be replaced.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Testimonial: "no because i gave the incorrect model number, it is kudco31vblo"
SOURCE: The soap dispenser doesn't open sometimes so the
Checkout this tip that I wrote about that problem...
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
SOURCE: Soap does not dispense from cup.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
SOURCE: Soap dispenser door is not opening
Hi tking01 The soap dispenser draw is operated by an electrical solenoid. It sounds like your solenoid has failed and needs replacing. This unit is located within the door itself. Regards
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Daniel
Daniel
