Dash lights do not work
Power is supplied to the instrument illumination by the "TAIL/ILLUM LIGHT" fuse, Fuse #4 (15 Amp) located in the dash fuse block under the left side of the dash. This fuse provides power for both the primary and secondary sides of the TAIL LIGHT relay. The Combination (Headlamp) switch provides a ground path for the primary circuit of the TAIL LIGHT relay. When the primary circuit is completed by the Combination switch, the secondary contacts close and provide power to the tail lamps as well as to all of the instrument illumination bulbs. The ground for the instrument illumination bulbs is a variable-resistance circuit which is controlled by the illumination controller. The final ground for both the combination switch and the illumination controller is Ground G302, located under the center console.
