20 Most Recent
JVC Arsenal KD-AR560 CD Player Questions & Answers
Need color codes
Do you need color codes for the deck.. they should be on a sticker on the unit itself...if you need color codes for the vehicle your driving thats another thing..does ur vehicle have a harnass?? Or was the stereo harnass and plugs cut?
black..ground
yellow..battery 12v
red..accessory
Blue/white..remote
orange/white..illumination
brown..phone
white..front left +
White/black..front left -
Grey..front right +
Grey/black..front right -
Green..left rear +
Green/black..left rear -
purple..right rear +
Purple/black..right rear -
JVC Arsenal...
Answered
on Apr 14, 2014
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
JVC Arsenal...
Answered
on Apr 24, 2009
Subwoofer instalation
Even if your JVC doesn't have outputs for a subwoofer you can hook it up with the a speaker wire to RCA converter.
You just spice your rear speaker wires to this device then connect RCA's to your amp.
I've used them before... works great.
http://cgi.ebay.com/ebaymotors/Speaker-to-RCA-Line-Level-Converter-Adjustable-High-Low_W0QQitemZ130143832174QQihZ003QQcategoryZ38636QQcmdZViewItem
JVC Arsenal...
Answered
on Dec 13, 2007
Lost security code on jvc kw radio
Press the "Hour" button (or right arrow button) to set the first and second digits of the code. Release the button once the four-digit code is accurately displayed. Press the "Mode" button to lock in the code you set. Turn the stereo deck on by pressing the "Source" or "Power" button to complete the reset.
JVC Car Audio &...
Answered
on Dec 20, 2020
My JVC KD-R426 keeps on saying warning check wiring and reset system. I've tried everthing but it still does the same. What must I do
Not sure if this will help any other owners since my answer is 4 years late, but this is what I found from another user. Apparently if you mess with the wiring too often, it goes in a safe mode which you need to do some button trickery to unlock the device from it's safe mode. These are the Steps.
1.Disconnect power supply
2.Press [MENU] and [UP arrow] buttons and keep holding.
3. While holding the buttons [MENU] / [UP arrow], connect the power plug again
A. The display will show "DC ERR"
*** if it still shows "Chk wiring ..." repeat the steps above until you get "DC ERR."
4. Press [UP arrow]; the display shows "DC1 ERR"
a. Press and hold [UP arrow] and it will show "DC1 OK"
5. Press [Down arrow], the screen will show "DC2"
a. Press and hold [DOWN arrow] and the display will show "DC2 0"
6. Disconnect the power from the back of the unit.
7. Remove the Face Unit.
8. Reconnect the power from the back.
9. Use a sharp object and press the [RESET] hole for 3 seconds and release.
10. Reinstall the face unit and turn on the power.
JVC Car Audio &...
Answered
on Dec 04, 2020
