Question about Boston Acoustics BA745 Computer Speakers
Can I connect my old Boston BA745 speakers (with two jacks) to a new laptop that only has a headphone jack?
Posted by jfebraun on
Stelios
    President:
  • 1,851 Answers
Yes, you can connect your 2 satelites at the headphone jack using an adaptor like this (I assume that the connector at each speaker is RCA). The problem is that you will get very low volume, even when you are all the way up at the settings. This is because these speakers don't have amplifier. Their amplifier was in the 3rd speaker, the subwoofer. So I don't think that the result will be exactly what you need.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 18, 2010
  • 7 more comments
  • jfebraun Sep 18, 2010
    Hi technical114 - thanks for your response. But I would like to clarify something: The way the Boston Acoustic speakers (model BA745) are set up, the two satellite speakers plug into the subwoofer, and the subwoofer has two 3.5mm male jacks that I need to plug into my new laptop. So I'm trying to plug the subwoofer, which I presume has an amplifier into my laptop.
    To give you even more details, one of the satellites plugs into the subwoofer with a male RCA plug, and the other satellite (which has a power/volume knob and a subwoofer volume knob) plugs into the subwoofer using a 3.5mm male plug and a circular plug with nine pins.
    So I'm not sure if you didn't fully understand my setup, or if you were suggesting to use only the two satellite speakers (which isn't something I want to do).
    Addendum: I just got off the phone with Best Buy's Geek Squad (I was typing to you while on hold with them), and they also believe an adaptor would work; this adapter would take my two 3.5mm subwoofer plugs and convert them into one. I'll let you know how it works out.
    Thanks again.
    Thanks again.
    Thanks again.
    Thanks again.
    Thanks again.
    Thanks again.
  • Stelios
    Stelios Sep 18, 2010
    You are right, I thought that you were about to use just the satellites. Since you need to use the full set with the sub-woofer follow this connection diagram:
    The 2 jacks from the sub to your laptop are for audio playback (the green one) and for mic use (the red one). This means that you can use the mic input that is located on one of the satellites in order to plug in a microphone, instead of using the mic input at the computer. This is convenient in cases you use a desktop; you connect the microphone at this speaker instead of trying to find the jack at the back of the tower.
    In your case leave the red jack from the sub woofer disconnected. Connect just the green one at the green laptop's jack.
    Thanks and regards
    Stelios
    direct fixya link:http://www.fixya.com/users/technical114
How do I hook to dell
Basically, these speakers come with universal PL plugs, which means, you can connect them to any music source that has a headphones jack (just like an iPod, iPhone, walkman, discern etc...) you should have same phone jack in your DELL - use the green plug to the OUT jack (should have a little marking of an arrow out or little icon of headphones) the pink plug is for microphone.
Nov 13, 2010 | Boston Acoustics BA745 Computer Speakers
How do i connect the boston BA745 comp. speakers to my gateway desktop?
Assuming you have the BA745 2.1 speaker set up, all of the cables connect to the subwoofer and then to the computer or the satellite speakers (these are built into the speakers IIRC). Take the cable with the black box (2 pins) to red and green. The red and green plugs go into the matching color ports on the computer and the pins on the black end fit into the jacks between the those for the two satellites. Plug the single end speaker cable into the subwoofer port all the way to the right on the back of the subwoofer. Plug the wire with the two plugs into the matching color jacks (blue to the left, red to the right). Then plug in the power adapter cable in the farthest left jack and plug in the other end to a surge protected power strip (that is plugged in and turned on).
Oct 24, 2010 | Boston Acoustics BA745 Computer Speakers
How do I plug my BA745 Boston speakers into a MAC desktop with one headphone outlet in the back?
I have the same speakers. It should have two plugs, one green and one pink. the pink plug is for a microphone. On the side of the speaker with the control knobs, you will find a headphone jack and a microphone jack. Unless you plan to plug a microphone into the pink microphone jack on the side of the speaker, you don't need to plug in the pink plug that goes to the PC. This is basically a microphone extension cord that runs through the speaker cord. That's all the pink plug is for. The green plug, on the other hand, is for your audio out. take the green plug and plug it into your computer's head phone outlet and you're good to go. You can use the speakers with any device that has a headphone jack. Just make sure you use the green plug, not the pink plug.
May 03, 2010 | Boston Acoustics BA745 Computer Speakers
How to conect the speaker to the computer? I got the monitor and a friend gave this kind of speaker but I don't find the conection betwen the computer to the screen, have the wire but Ican't find the...
To connect your audio system to your pc do the following:
Step 1. Take the two-pronged cable that plugs into the "Out to PC" and locate the green and pink cables.
Step 2. Plug the green audio end and plug this into the Headphone (line out) jack on your computer.
Step 3. Take the pink audio end and plug this into the MIC jack on your computer.
May 01, 2010 | Boston Acoustics BA745 Computer Speakers
Ba745 user manual
I'm sure that there is some special software available, but its unnecessary. You can just plug them in and have a listen. Sorry, I'm not sure where to find a manual.
Mar 19, 2010 | Boston Acoustics BA745 Computer Speakers
Can boston acoustics BA745 be hooked up to toshiba hdtv
Yes it can, just buy a converter adapter at a local electronics store, Just ensure that the TV has an earphone jack. Good luck
Mar 03, 2010 | Boston Acoustics BA745 Computer Speakers
Can the Boston BA 7900 be converter to use with TV or DVD Player?
Yes, but so far I can only get the 2 front speakers and subwoofer to work.
You need a wire that converts a headphone-style jack (like the green one with the Boston speakers) into a red and white AV connection (typical CD/DVD, etc. connection). I've had this connector for a long time and I'm guessing it's under $15. You connect the green Boston speaker connection to the converter end (mine connects to the back end of the headphone-jack (which has a hole for the connection) and the red/white AV connectors to your TV.
I'd been trying to solve the problem too for a long time. Only problem is that I can't get all 5 speakers to work because I think the red/white connector doesn't work with all 5 speakers. I have yet to figure out how to make all 5 work, but the system gives great sound anyway. You will have something like a 5.1 system with your computer speakers, the Boston speakers and subwoofers.
One more issue is that if you connect it directly to the TV, you have to manually turn the Boston speakers on and off.
Nov 06, 2009 | Boston Acoustics BA7900 Computer Speakers
Boston Acpustics BA745
you cannot plug the phono jack directly into the motherboard, there needs to be another piece that you can add, it has a yellow speaker sticker that you install into the computer, onto the motherboard. it is not an add-on card, but an accessory you can buy. this is because the speakers are self-powered, meaning that they need power from the motherboard instead of an AC adapter
Nov 17, 2006 | Boston Acoustics BA745 Computer Speakers
Boston Acoustics BA745 Computer Speakers Logo
5,386 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
