1998 Chevrolet Malibu Logo
Posted on Nov 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
ZJ Limited
Level 3:
  • Chevrolet Master 17,989 Answers
  • Posted on Nov 05, 2010
ZJ Limited
Chevrolet Master
Level 3:
Answers
17989
Questions
0
Helped
14450199
Points
60858
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps (remember to rate this).
Alan H
Level 2:
  • Expert 139 Answers
Alan H
Expert
Level 2:
Answers
139
Questions
0
Helped
95115
Points
339
Since you are planning to install an OEM headunit / radio, you can replace the factory with an aftermarket plug, see included link:
GM harness into radio
The factory colors are as follows:
Plug C2:
Constant 12V = Orange
Ground = Black / White
Ignition 12V = Yellow
RF Speaker (+) = Light Green
RF Speaker (-) = Dark Green
LF Speaker (+) = Tan
LF Speaker (-) = Gray
Dimmer = Gray
Illumination = Brown
Plug C1:
RR Speaker (+) = Dark Blue
RR Speaker (-) = Light Blue
LR Speaker (+) = Brown
LR Speaker (-) = Yellow
VSS Input = Dark Green / White (for use with speed controlled volume)
Plug C3: (connects to external cassette player)
Remote Turn-on = Pink
Dimmer = Gray
Audio Common = Light Blue
Right Aux. Signal = Light Green
Left Aux. Signal = Orange / Black
E & C Buss = Dark Green (sorry cannot describe function of this wire)
2answers
98 Acura cl 3.0 original stereo OEM wires were cut installing aftermarket stereo what are the color codes on the original stock harness so I can route it to the new wiring harness kit
read (you meant main harness to radio sub harness.)
and car may have 5 or more harness for 5 or more very complex radio head end options new,so only the real service manual covers all that for sure,or if lucky 2nd fiddle here.
https://eautorepair.net/Marketing/Default.asp
I have a 2001 toyota corolla got the 1.8 L. The car came with an aftermarket radio but only the back left speaker is working well cause of my experience in installing car stereos I pulled the radio and...
Sound test/click test each speaker with a flashlight battery at the radio end of the harness. Hold the ground of battery on metal frame or ground wire and touch the speaker wire to the hot post of the battery. If speaker doesn't click click/static, speaker is bad or harness not connected to speaker. If each passes the test and clicks, your speaker control on the radio isn't working. Being a stereo installer you should know this, or possibly forgot to do so. I've neglected to do the same for the "hurry" mode had kicked in.
Trying to install stereo in 01 impala. I need to know the stereo wiring diagram. I keep reading that the yellow is 12v constant but have no yellow wire. Any help? Factory harness was cut out -______-
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: White
Front Speakers Size: N/A
Front Speakers Location: N/A
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Wire diagram
if you call the local stereo shop they likely have a conversion wiring harness or can build a proper 1 for you so you can allways remove it and reinstall original if nessarry
1helpful
Aftermarket stereo wiring harness does not fit oem connectors. ordered stereo and harness together fom online car stereo.com. calledout a metra #70-1761. plugs will not fit either male plug. factory plugs...
Theres a standard amongst most stereos, so if these colors apply, then you will be right,
Red is Ignition power
orange is direct power
Black is earth
blue is for phone
White is for electric arial
then there will be four coloured wires with matching color trace wires, these are the speaker wires.
Hope this gets you going, good luck.
4helpful
3answers
I am trying to install a new stereo in a 94 rodeo but my wire harness is cut off
here are the wire colors and what each does.
1994 Isuzu Rodeo Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Brown/White
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue/Yellow
Left Front Speaker Negative Wire (-): Yellow
Right Front Speaker Positive Wire (+): Green/White
Right Front Speaker Negative Wire (-): Gray/White
Car Audio Rear Speakers Size: 4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Red/White
Right Rear Speaker Positive Wire (+): Orange
Right Rear Speaker Negative Wire (-): Black/Orange
5helpful
2answers
Need to know the wires to install a deck for 97
Red is power to from ignition to cd deck
Yellow is direct power from battery to cd deck to hold the memory.
Black is ground
Blue is only needed if you are hooking up an amplifier.
I always suggest buying a wire harness quick connect system for $5, then you won't have to cut origional car wiring. If by chance you are taking the original wire route, then go to installer.com to find which wires on the car are for what.
10helpful
I want to install a stereo in a 2001 grand am se but the wires were cut.
Here are the wires colors of the harness and what they do.
2001 Pontiac Grand Am Car Audio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Mounted behind trim in the left side of the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
