It gives me E100 error how do i clear it coz i cant photocopy nor print from the machine.
Problem with Canon IR1024 Now the screen is reading System Error E100 PLEASE HELP!!
When l photocopy with my Canon iR1024i it keep showing me system error E100 and when it comes out it print top black
please any help
Check the laser unit clean optics and polygon check wiring check also the drum rotating or the blade function reset clear data last is board
SOURCE: canon ir 400 photocopier
What is the sub error code E805-" " -007 is is a blown fan and a blown fuse on the DC control. " " -002 could be a broken connection or pinched wire under the adf pillar on the right rear near the fixxing unit. If your have more info. on the code let us known..... Good luck
SOURCE: canon IR2020 photocopier
BD detection PCB failure
The BD detection PCB is faulty.
- Check the connector of the BD detection PCB.
- Replace the laser scanner unit.
- Replace the DC controller PCB
SOURCE: How do I clear error E100 on my Canon GP215
BD error has occurred.
• The laser unit has a fault.
• The BD PCB has a fault.
The BD signal is not generated during image formation
because this error is related to LASER UNIT & BD UNIT we suggese try to repairing with help of a technician, don't self.
Thank's for using FIXYA
Apr 19, 2009- Press additional functions
press #
press + key until display reads #7 printer
press set
press + key until display reads #4 printer reset
press set
press - key for yes
unplug copier wait a minute and plug it back in
This resets E-000 codes maybe that will help
Good luck
I found this on someones elses solution maybe it will help you...
Assist on how to fix problem on a photocopying machine( ir1024a)
