Symbol Motorola MC9090 Mobile Computer Logo
mike Teetzel Posted on Jan 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 9090 keyboard is typing the wrong characters. ie... The 'a' button is acting like the tab key.
The keyboard still works but all the keys are shifted around. The onscreen keyboard works fine. Need to know if there is a fix for this. I've been searching and see nothing similar.
alx blx
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on May 23, 2016
alx blx
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
8090
Points
87
Same issue,
solved swapping keyboard with different layout form another MC9090, even other one works properly.
David Germain
Level 1:
  • Contributor 20 Answers
  • Posted on Nov 06, 2013
David Germain
Contributor
Level 1:
Answers
20
Questions
0
Helped
13725
Points
23
Try doing a cold boot on the unit. press the power button for ages, it will say warm boot, keep holding it and it will switch off at this point let go of the power button. this should do a cold boot.
Anonymous
Level 2:
Sergeant:
  • Expert 378 Answers
  • Posted on Jan 31, 2013
Anonymous
Expert
Level 2:
Sergeant:
Answers
378
Questions
Helped
78253
Points
816
1 Related Answer
Symbscanners
  • 74 Answers
  • Posted on Oct 26, 2009
SOURCE: Symbol scanners (several models) not recognizing Code 39 Extended
The barcode must be a Code 39 barcode, not a Code 39 Extended or Full ASCII barcode. The Enable Code 39 Full ASCII must be scanned from the Symbologies section of the LS2208 Product Reference Guide (page 186 of 342). The Enable Function Key Mapping barcodes would have to be scanned if you are seeing something other than the tab happen when you scan into your application. In Word, for instance you will see the italics enable/disbled whenever the $I is encountered in the barcode.
As for the Covert to Code 39 Full ASCII- that is for Wand and Scanner emulation. The setting was having no effect because you were not connecting to either of these hosts.
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
How to use accents when writing in Spanish in a Dell Precision m4500 laptop?
On Windows XP
  1. Log On
  2. Click the Start button
  3. Click on Control Panel
  4. Click Regional and Language Options - a new window will pop up
  5. Click the Languages tab
  6. Click on the Details button
  7. Click the Add button - a new window will pop up
  8. Select United States-International (keyboard layout menu)
  9. Click OK
  10. Click Apply
  11. Read the instructions for "Using the U.S. - International Keyboard" below.
Note: You will now have a keyboard icon on the taskbar (usually on the right side). To switch between keyboard layouts click the keyboard icon on the task bar and choose which layout you want to use. Changing the keyboard layout will only affect the log on profile used. No other users will be affected.
Windows Vista
  1. Start-->Control Panel-->Clock, Language, Region-->Change Keyboards
  2. New Window: Click the Change Keyboards button
  3. New Window: Click the Add button
  4. Select United States-International keyboard
  5. Click OK
  6. From drop down menu (Default Input Language) select United States International
Using the U.S. - International Keyboard If you followed the above directions carefully, your keyboard will now react slightly differently than it did before. First of all, notice that if you strike the single apostrophe (') key, nothing happens. To type the single apostrophe now, you must strike the single apostrophe key and then strike the space bar. When you strike the spacebar, the apostrophe will appear.
The next thing to note is that the quotes (") key behaves the same way as the apostrophe key. You must first strike the quotes key and then strike the space bar in order to create the (") symbol. These two minor inconveniences are more than made up for by the ease with which you can now type the special characters.
To type the special characters, two keystrokes are required. To type the ?, you need only strike the apostrophe key and then the letter a. The other characters are just as easy:
  • ? = ' + a
  • ? = ' + e
  • ? = ' + i
  • ? = ' + o
  • ? = ' + u
  • ? = ~ + n
  • ? = " + u
To type the special punctuation characters, you need to hold down on the Alt key while you strike the appropriate punctuation mark. On some keyboards, only one of the two Alt keys will work for this.
  • ¡ = Alt (hold down) + !
  • ¿ = Alt (hold down) + ?
Using Cryptic Codes If, for some reason, you don't want to change your keyboard, you can always type in the troublesome cryptic codes. Using this arcane system, the following codes apply:
  • ? = Alt + 0225
  • ? = Alt + 0233
  • ? = Alt + 0237
  • ? = Alt + 0243
  • ? = Alt + 0250
  • ? = Alt + 0241
  • ? = Alt + 0252
  • ¡ = Alt + 0161
  • ¿ Alt + 0191
When using this utterly out-dated system, there are two important things to remember. First, when you type in the numbers, some keyboards require that you use the "numeric keypad" located to the side, rather than the numbers along the top. Second, on some keyboards, only one of the two Alt keys will work for this.
A few keys on my Acer 4420 are not working properly and I have no idea as to why. The keys are my o, p, l, ' and period keys. When I do use them they type out random characters. My o keys types out i75`,...
If a neighbor will let you,disconnect their keyboard and try it on yours.If it works normal,the problem is the keyboard.They are fairly cheap to buy brand new.If it does not go away,something is wrong,most likely the IC which interprets the keyboard signal and converts it to letters.It sounds most likely to be the keyboard because it is a few characters consistently.Perhaps something was spilled in that section as they are quite close together.Good luck,Greg
My toshiba laptop is typing wrong characters but my wireless tevion keyboard is o k. Is there a solution to this ?
Sounds like the laptop keyboard went bad and thats why its typing wrong characters. Best way to verify this is to use a USB keyboard on the laptop, if the USB keyboard is typing the correct keys then you know the laptop keyboard is bad. If the USB keyboard is typing the wrong keys as well then you know its a setting in windows that is causing the keys to type wrong characters.
1helpful
2answers
Trying to get the asterisk @ for email on a computer
Probably your keyboard is set to a different character set or language. To fix this go to control panel and click keyboard properties, there should be a tab for input locals. This sets the language and character set for your keyboard. To use various characters, you can use start , then type charmap.exe in the box and it will bring up a character map where you can select various characters such as the copyright sign etc. to use. Most windows from 2000 newer also have osk.exe, this draws up an onscreen keyboard you can click with your mouse to type.
Well my keyboard types the wrong characters for some of my buttons, the # key comes up as a | and the @ key comes up as a ", i've downloaded my keyboard software but it hasn't changed anything
Please follow these steps
Go to the Control Panel
Click on "Regional and Language Services"
Click on the "Languages" tab
Click on "Details"
Click on "Key Settings"
Select "Switch Between Input Languages" and click "Change Key Sequence"
Make sure all the boxes are unchecked.
Do the same thing with "Switch to... (Keyboard type)"
Click "OK"
Click "OK"
Click "Apply"
Click "Ok"
Reboot
This will resolve the issue.
Keyboard types wrong character
The problem is with your keyboard not with its s/w. if u have installed vista and still the problem remains then it is problem of keyboard. pls rush to nearest service center. don't do much experiment
2answers
Screen only displaying keys that are on blue on keyboard
sir if u wants to type the special characters then press the shift key before pressing that button.
1helpful
Keys on keyboard typing wrong characters
Instructions for Windows Vista
  1. Click Start and then Control Panel
  2. In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner)
  3. Open Clock, Language, and Region
  4. Click on Regional and Language Options.
  5. Click the Keyboards and Languages tab and then click Change keyboards.
  6. Under Installed services, click Add.
  7. In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK.
  8. The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes
  9. You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
Instructions for Windows XP
  2. In Control Panel, if you are in Category View, click on Switch to Classic View (top left corner)
  3. Open Regional and Language Options.
  4. Click on the Languages tab.
  5. Under Text services and input languages, click on the Details button.
  7. In the Add Input Language dialog box, choose the input language and keyboard layout or Input Method Editor (IME) you want to add.
  8. Click OK twice. You should now see a language indicator in the System Tray (located at bottom right hand corner of the desktop by default). You can switch between different input languages (= keyboard languages) by pressing the Alt + Shift keys
2helpful
Keyboard typing wrong characters
turn off the keylock on boot- this is an option in the bios. also you might be able to use the fn key and turn it off manually
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
