Symbol LS2208 Handheld Logo
Question about Symbol LS2208 Handheld
How do I get my scanner to go to the next line/box when using Excel?
Posted by jon_taylor on
Buddy Mcsparrin
  • 1,684 Answers
In your programming manual there is a barcode scan that needs to be scanned in that adds the carriage return function. To do this you will first need to scan the barcode to put the unit into program mode, then scan the carriage return barcode, then scan the end programming code. Now when you scan a barcode the scanner will add the return to the sequence it sends to the computer. If you can't find your programming book you can download the sheets from the Symbol web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Apr 15, 2010
How do I get horizontal lines on Microsoft Excel 2010?
Highlight the cells containing your words, right-click and select "Format Cells", then go to the "Borders" tab on the dialog that appears. You can do all sorts of neat stuff there. For your purposes, pick a line weight, then click the sample box's bottom line.
tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
on Jun 26, 2011 • Computers & Internet
2answers
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
What would I put under the suffix and prefix when bar coding? My scanner is Symbole LS 2208
Hello Norma, you can use the suffix or prefix to send characters, which are not included in the barcodes tgehter with the scanned barcode data.
If you dont need any character before or after the data, you can leave it blank.
It is usually used to add an Enter or Tab to switch to the next line, while scanning to some application like excel.
Cant open Excel files. Not even from emails with Excel attached
either your MS Office Installation is currupt or your system in infected with a virus.
Please scan your system using a good virus scanner. (Please uninstall any prior scanner if you have and pl avoid using McAfee for the time being).
Now open your excel go to Office button
Office Button --> Excel Options --> Resources --> Diagnose
if problem comes during diagnosis, please connect your system to internet and if fails, please reinstall office again.
Good Luck
Zulfikar Ali
[email protected]
2answers
Trying to write a loop using excel text boxes such as: Dim x as integer for x= 0 to 100 textbox(x).backcolor=vbWhite x=x+1 next x Not working any thoughts thanks
You don't say how your program is not working, but one of the problems with your code is where you have x=x+1. Loops using For Next don't need a statement to add 1 to the value of x. The variable x will automatically be increased by 1 each time the program reaches the Next x statement. Your program should be
Dim x as integer: For x=0 to 100: textbox(x).backcolor=vbWhite: Next x
Have fun
Scanner displays on a same row in excel how do I get it to automatically move the curser to the next line on my second code scan
If you would like the scanner to drop down to the next line scan the barcodes Scan Options, Data Suffix, Enter from the Quick Start Guide that should have come with the scanner. If you do not have the QRG then download the Product Reference Guide from this link:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=134926365&stateId=0%200%2014579837
The barcodes are on Adobe pages 222 and 223 of 342 in this manual.
2helpful
2answers
Move to next cell in excel
In Excel 2003 Offline help, i see this helpful note:
Change which cell is selected next When you press ENTER to finish working in a cell, Microsoft Excel moves you to an adjacent cell or leaves you in the current cell.
  1. On the Tools menu, click Options, and then click the Edit tab.
  2. To move to an adjacent cell, select the Move selection after Enter check box, and then select a direction in the Direction box. To stay in the current cell, clear the check box
for our Symbol scanner we are using this apparently is not working, but it might for you!
3answers
Excel working
there are programs available in the net that can retrieve password of excel sheet..some are free and some are not. try searching the net.
Top Symbol Computers & Internet Experts
George Etukudo
Ngoro
john h
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
