20 Most Recent Symbol MC9000-G Portable Terminal Questions & Answers
2answers
Freezes on the warm boot screen MC9000
This can be for a number of reasons.
First thing would be to try and cold boot the device:-
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger
If that fails next thing would be to try and re-flash the operating system. This is done by using an SD card and loading the latest operating files onto it. The SD card slot is located under the keypad. A cross head screwdriver is required to remove the keypad. Search on symbol software download site for the latest. The download also has a readme with detailed instructions. Once the files are on perform a cold boot.
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger. Drop the terminal in a cradle so that it runs on external power.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
1/11/2017 2:47:04 PM • Symbol MC9000-G... • Answered on Jan 11, 2017
Why my mc9191 power off after warn boot
Contact Motorola Solutions Get Support or Zebra Technologies Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly. Mark Motorola Mobility Support
1/19/2015 6:15:07 AM • Symbol MC9000-G... • Answered on Jan 19, 2015
Cleanbootandblank de la mc9000
Si es Windows CE5, no se puede hacer cleanboot and blank. Necesitas cargar el sistema operativo de nuevo. Si es Windows Mobile 5, te puedo pasar los archivos para hacer clean boot.
7/14/2014 9:07:09 PM • Symbol MC9000-G... • Answered on Jul 14, 2014
I need to seup MC9000G scanner to read code 93 bar
Enable code 93 in symbologies on the scanner/imager settings.
11/29/2013 2:32:54 PM • Symbol MC9000-G... • Answered on Nov 29, 2013
0answers
0answers
Hello jumpmaster. When an MC90XX does this, it means that something has gone wrong with the Operating System file execution. Sometimes a cold-boot can fix it (instructions below). If not, then there is a problem with the OS files. If you purchased your MC90XX from Motorola/Symbol you should be able to download a copy of your OS to reinstall. The file will include a readme.txt that will walk you through the process. I hope this solves your problem. Good luck!
  • To Cold Boot
  1. Press the primary battery release to partially eject the battery.
  2. While the battery is partially released: simultaneously press and release the trigger and power button.
  3. Push the battery back in until it clicks.
  4. The MC90XX should power up and start it's boot-sequence.
1/6/2010 4:42:51 AM • Symbol MC9000-G... • Answered on Jan 06, 2010
My Kenwood 1 ton inverter ac outer not starting some times start show compressor symbol and then turn off and not start again doesn't show any error please guide
If your Kenwood 1 ton inverter AC is having trouble starting and sometimes shows the compressor symbol before turning off, there may be a few things you can check to diagnose the issue.
  1. Power Supply: Check that the AC is receiving proper power supply, and the circuit breaker is not tripped. Sometimes, due to voltage fluctuation, the compressor may not start.
  2. Dirty Air Filters: Check the air filters and clean them if they are dirty. Dirty air filters can reduce the airflow and cause the AC to malfunction.
  3. Faulty Thermostat: If the thermostat is faulty, it may not be able to detect the temperature properly and cause the compressor to not start. You can check this by setting the temperature to a lower level and see if the AC starts.
  4. Low Refrigerant Level: Check the refrigerant level in the AC. Low refrigerant levels can cause the compressor to not start.
If none of these steps solve the issue, it may be best to contact a professional AC technician to diagnose and repair the issue.
3/3/2023 10:16:08 PM • Symbol Computers... • Answered on Mar 03, 2023
2answers
How to type degree symbol on mac
There are a few different ways to type the degree
  1. Use the keyboard shortcut: Press and hold the Option key, then press the letter K on your keyboard. This will insert the degree symbol.
  2. Use the character viewer:
  • Go to the Edit menu and select Emoji & Symbols.
  • In the search field, type "degree".
  • Double-click the degree symbol to insert it into your document.
  1. Use the ASCII code:
  • Press and hold the Option key and the Shift key.
  • Press the number 8 on the numeric keypad. This will insert the degree symbol.
I hope this helps! Let me know if you have any other questions.
1/6/2023 8:09:59 PM • Symbol Computers... • Answered on Jan 06, 2023
2answers
British Gas T4 RF My battery symbol is flashing. Do I need to change the battery?
no info generic answer --have battery and alternator tested--check belts and connections
1/5/2023 8:41:08 PM • Symbol Computers... • Answered on Jan 05, 2023
Videocon ac remote not working
Hi, Please reach out to videocon on twitter to help take care of this issue: @VideoconIndia . You can tweet their handle with the issue included. You can also call 1800 1370 444 to reach them. I believe that is a number based in India. Thank you.
7/27/2022 11:25:03 PM • Symbol Computers... • Answered on Jul 27, 2022
How do I get firmware or a plugin for Zebra Symbol LS4278 Scanner - Model LS4278-SR20157ZZWR
Use " Scanner update utility " to update the firmware. after this try to configure scanner with " 123 scan utility " https://www.zebra.com/us/en/support-downloads/scanners/general-purpose-scanners/ls4278.html#pageandfilelist_895c
5/20/2022 10:41:28 AM • Symbol Computers... • Answered on May 20, 2022
Typewriter Brother AX-22, When typing, a wrong symbol showed up.
I lack access to the keyboard. That said, according to the manual on page 13, depressing the code button and holding it down while pressing another key will access the green symbol on that key, part of an alternate set of characters. It you see a green / mark on a key, you have your answer. https://www.manualslib.com/manual/376756/Brother-Ax-22.html?page=17#manual The page 17 you see in the link pulls up page 13 in the manual.
12/19/2021 6:06:53 PM • Symbol Computers... • Answered on Dec 19, 2021
I have a te 2200 and need to change currency symbol from euros to pounds. Please help the user manual isn't much help
The CE key is a toggle between foreign currency and local currency at a preset exchange rate. That is, it converts both ways. If this does not help, you may have to consult casio support for your region.
12/22/2020 8:36:34 PM • Symbol Computers... • Answered on Dec 22, 2020
Symbol MC9000-G Portable Terminal Logo
11 questions posted
Popular Products
Top Symbol Computers & Internet Experts
 Mike M
Mike M
Marvin
Marvin
Paul Carew
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Symbol Computers & Internet
Most Popular Question
freezes warm boot screen
  • Computers & Internet
