gina stamm Posted on Jan 26, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you change the outter chip from one epson ink cartridge nx 415
Sudeep Chatterjee
Level 3:
  • Master 3,267 Answers
  • Posted on Jan 26, 2013
Sudeep Chatterjee
Master
Level 3:
Answers
3267
Questions
10
Helped
1159322
Points
10260
Don't let your ink levels drop below 25% before refilling and resetting your cartridges. There is an inner and an outer chip on these cartridges. The inner chip disables the outer chip when it's contacts are no longer bathed in ink. So, it doesn't matter if you "reset" the outer chip after refilling your empty cartridge because the chip was disabled.
But the outer chip is not available in the market hence refilling has to be done before you have used 75% of the ink. Yes you can replace if and only if its not from a empty cartridge
5 Related Answers
Anonymous
  • 28 Answers
  • Posted on Apr 14, 2009
SOURCE: Installed new OEM Epson ink cartridges, get error message 2. Cartridges are installed correctly and tested ok. Chip problem? Print head problem? Cartridge problem?
Go to printers and faxes, and uninstall the printer.
reboot, this should solve the problem
Anonymous
  • 121 Answers
  • Posted on Apr 28, 2009
SOURCE: My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
Anonymous
  • 134 Answers
  • Posted on May 03, 2009
SOURCE: My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Anonymous
  • Posted on Oct 14, 2009
SOURCE: Epson cx8400 Black Ink Cartridge doesn't work on Printing
I put alcohol in inside the printer, where you insert the ink cartruges then cleaned with paper towl and it works for me.....
Anonymous
  • Posted on Jan 29, 2010
SOURCE: Continuous Ink System Epson R1900 "Ink on" light illuminated
hi, the most possible is that your chip on that cartridge is broken or damaged. You may need to replace a new chip.
Or you didn't contact well the chip with printer contact pins. Try many times.
If still problems pls feel free to ask me.
Danny
[email protected]
www.equnxin.com
BOUGHT NEW CARTRIGE FOR MY NX 415 AND THEY AREN;T REGOGNIZED!
If the cartridge is not the same code as the previous used by the printer, then it will not be compatible. Your printer has been replaced by Epson Stylus NX415 All-in-One
  • One 69 Black Ink cartridge (T069120)
  • One 69 Cyan Ink cartridge (T069220)
  • One 69 Magenta Ink cartridge (T069320)
  • One 69 Yellow Ink cartridge (T069420)
  • Therefore, ensure that the catridge follows the above code (69).
    Best regards.
    NX 415 Black will not print.
    Hi
    The ink reservoir for the black ink doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual, clean the jets and then try to print from the printer's self test
    Goodluck
    3helpful
    2answers
    My epson stylus color 400 will not print in black...I have replaced the two ink cartridges...if I type in color it prints in color...if I type with black ink...it does not print...please help
    I had the same problem.
    Solution: The black don't print in standard resolution (regular paper)
    Set your printer in higher quality paper and your black will print.
    This is another problem with Epson nx 415..................
    Good luck !!
    Lost manual ...need to change ink cartridge in Epson Stylus NX 300 4 in 1 printer...thank you, appreciatively, mrs. preston
    Hello
    You can get pictorial view to change ink cartridge from the Epson Web site by clicking HERE you just need to click on "Remove and Install Cartridge"
    Hope This helps, if so do rate the solution
    My Epson stylus NX 400 continually says "error..replace ink cartridges" I did and nothing changed.
    Assuming the cartridges are new (since almost all of them have a chip on them)
    1. Make sure you match color of cartridge with the correct slot. If same error, then
    2. remove all carts. and clean both cartridge holder and cartridge contacts with alcohol.
    good luck
    21helpful
    5answers
    My Epson NX415 does not recognize refilled and reset cartridges. What can I do about it?
    Don't let your ink levels drop below 25% before refilling and resetting your cartridges. There is an inner and an outer chip on these cartridges. The inner chip disables the outer chip when it's contacts are no longer bathed in ink. So, it doesn't matter if you "reset" the outer chip after refilling your empty cartridge because the chip was disabled. I'm really curious how you refilled these cartridges yourself without souring yourself on refilling from the experience. I own a Cartridge World ink refilling store and I refilled a set of these cartridges when we had replacement chips available (we don't now because our chip distributor was violating Epson patents) and it was an absolute mess, took forever, and the cartridges still didn't work in our test printer.
    2helpful
    Lost instructions. How do you change the ink cartidge on Epson sx200?
    How do I change the ink cartridges on my new Epson NX 215 printer, I do not know how to move the ink holder.
    Bad printing after changing 2 inks also clicking noise not before
    shouldn't be the ink. I assume you have an epson as in the picture. my ink refill kit mentions that "epson intellidge chipped cartridges" require an "ink level resetter" to complete the kit. So if you have these cartridges even once refilled the chip tells the printer the cartridge is still empty so you'll need to reset the chip with the ink level resetter.
    16helpful
    3answers
    1helpful
    2answers
    k24674
    ADMIN Andrew
    ADMIN Andrew
