I hit bake & it says off. I can't get the oven 2 say anything but off. Usually I hit "bake" & then up arrow 2 set temp but now as soon as I hit 'bake' or anything else it says 'off'. Hitting cancel doesn't help at all.
SOURCE: My oven is beeping!
Try turning it off at the mains, then whilst turning it on, press and hold the cancel button.
Check the fuse and any other electrics on the same ring; eg. Washing Machine - this can indicate that the circuit breaker has tripped, replace any fuses and check integrity of electric on that circut, then flick it back on.
SOURCE: OVEN TEMP STUCK ON 100F
check your house connections to the stove turn the breaker off first then reply to me
SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
SOURCE: F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
SOURCE: I accidentally hit the time bake button instead of
Are you getting any codes? Sounds like one of your touchpad buttons is stuck. CAUTION: Turn power off to oven at circuit breaker. I would take the control panel off disconnect the ribbon from the touchpad and take a pencil eraser and clean the contacts. Reconnect ribbon connector back together. If this does not help write back..
