20 Most Recent Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven Questions & Answers
I have a 27" Frigidaire
If the elements are good and you have checked the obvious connects etc. then it would seem to be the control circuit.
9/22/2017 11:17:08 PM • Frigidaire 27... • Answered on Sep 22, 2017
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
5/12/2016 8:33:43 PM • Frigidaire 27... • Answered on May 12, 2016
2answers
I need a controls manual for a frigidaire LEEB30T9FEA. I have the Owners Manual and the Installation Guide but neither has how to use the controls of the oven.
Hello - I understand you are seeking a control manual for a Frigidaire Double Electric Wall Oven LEEB30T9FEA. You can download the manual to your unit here under the Timer Guide. I hope you find all the information that you need.
6/2/2014 8:20:32 AM • Frigidaire 27... • Answered on Jun 02, 2014
F4 code is displayed and oven beeps continuously
Hello Duane, I am happy to assist you. Typically, error code F4 indicates a lockout error. Try resetting the unit by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) or the Lockout Control Board on the appliance will need replacing.
8/20/2013 10:20:19 AM • Frigidaire 27... • Answered on Aug 20, 2013
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents. Tools needed: Phillips head screwdriver or small quad bit driver. A. Open Door remove 2 screws and washers on door lining at door hinge area. B. Refer to owners guide with door in broil stop position lift door assembly off hinges. C. Lay door on table, position so that handle hangs freely over edge of table D. Remove 2 screws and washers that secure handle to lining assembly. E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side F. Lift door lining up and out of wrapper trim assembly. G. Lay lining assembly on table with wool shield/inner part of lining facing up. H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield. I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H. J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly. L. Reassemble in reverse order. I hope this information helps to some degree.
5/31/2013 11:54:32 AM • Frigidaire 27... • Answered on May 31, 2013
INSTRUCTION MANUAL FOR LEEB30T9FEA
Hello Brent Delong - I understand you are seeking a control manual for a Frigidaire Double Electric Wall Oven LEEB30T9FEA. You can download the manual to your unit here under the Timer Guide. I hope you find all the information that you need.
3/12/2013 11:52:01 PM • Frigidaire 27... • Answered on Mar 12, 2013
Oven door display comes on
Hello mapatt - Are you able to open or latch the door? Try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. This will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs. The unit could possibly be experiencing a wiring failure, faulty light switch, door latch or EOC.
1/30/2013 2:05:17 PM • Frigidaire 27... • Answered on Jan 30, 2013
Replace light bulb
Hello tony sunlitis - I understand that you would like to know how to replace the light bulbs in your unit. So I can assist you better in pinpointing you the information, may you please provide me the model number.
11/29/2012 4:51:55 PM • Frigidaire 27... • Answered on Nov 29, 2012
0answers
Oven smokes
Be the first to answer 2/6/2012 12:54:05 PM • Frigidaire 27... • Posted on Feb 06, 2012Be the first to answer
Where can i get a downloadable instruction manual
try this site http://www.manualsonline.com/
2/27/2011 3:11:14 AM • Frigidaire 27... • Answered on Feb 27, 2011
Self-Clean oven fan will not turnoff and the door still locked
Have you tried to unpulg it and see if it unlocks
1/1/2011 12:00:07 PM • Frigidaire 27... • Answered on Jan 01, 2011
The upper oven does not
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
11/24/2010 1:59:10 AM • Frigidaire 27... • Answered on Nov 24, 2010
My oven door is locked.
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    10/10/2010 12:20:54 AM • Frigidaire 27... • Answered on Oct 10, 2010
    Upper oven onlyworks on broil. When I turn the
    could be a bad element or a wire burned out,going to the element in the back of the oven. you will have to pull out the unit to check the wire. turn off the power to the oven before you start. element can be checked from the inside.
    10/6/2010 3:50:07 PM • Frigidaire 27... • Answered on Oct 06, 2010
    F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    7/30/2010 4:06:45 AM • Frigidaire 27... • Answered on Jul 30, 2010
    How do I get behind
    I hope this link may be helpful for you.
    Kind Regards.
    7/17/2010 12:21:11 AM • Frigidaire 27... • Answered on Jul 17, 2010
    Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven Logo
    54 questions posted
    Top Frigidaire Ovens Experts
    ZJ Limited
    ZJ Limited
    Paul Carew
    Kell Le
    Level 1 Expert
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
    View Most Popular
    Frigidaire Ovens
    • Frigidaire Ovens
    Most Popular Question
    instruction manual leeb30t9fea
    • Ovens
