Hello, I have cleaned every filter I can find many times, including the Condensor as shown in the manual. The "clean filter" lamp keeps flashing. As soon as I turn it on, and turn the dial it begins flashing, if I unplug it and plug back it, it start flashing as soon as I turn the dial. Again, I've cleaned all lint filters and the condensor. Sometimes it starts beeping at me the shuts down, but usually finishes a load. Would appreciate any help. I download the service manual, but it had no reference to this problem other than "clean the filter" Thanks for your help.
SOURCE: Clean Lint Filter Light Keeps Dryer from starting
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
SOURCE: Bosch Axxis dryer - lint filter indicator lights up
Make sure the exhaust vent duct is clean all the way to the outlet.
SOURCE: lg tdc70040e I have this dryer. I dont start
I have the same problem, but it starts when I "help" the motor by turning the bac side fan. Then it starts. When it starts the clean filter light goes.
Could it be the motor? The motor is compact and without brushes..?
johnson
SOURCE: Turned on dryer & tried to start but it gave a
there is a sensor located beneath the lint filter, more the likely the dryer sheet residue is on it, gently brush it off, it has two screws. As far as the loud thud noise is/may be a problem with the drum/rollers/glides/belt/idler arm/motor Here is a website that will assist you, once the filter light goes off and the drum will not turn.Good Luck Tim
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Item # 686172
In Stock
The blower wheel draws air through the dryer
and pushes the air out the vent. If the dryer won't stop, the blower
wheel may not be spinning properly, which reduces the air flow. Check to
see if the blower wheel is securely fastened to the drive motor shaft.
Skill Level Skill Level
Part Replacement Video
$23.40
Quantity:
Item # 528055
In Stock
The heating element assembly warms the air
before the air enters the dryer drum. If the dryer won't stop, it may be
because the heating element assembly isn't working - which greatly
increases the drying time. Check the heating element for continuity.
Part Testing Video
$91.05
Quantity:
Item # 2659
In Stock
Dryer sheets and fabric softener can leave a
residue on the lint filter, reducing the air flow. If the dryer won't
stop, check to be sure air can flow freely, clean the filter as needed.
$38.95
Quantity:
Item # 469522
Although not as common, if the dryer won't
stop it may be because the moisture sensor is either defective or coated
with fabric softener. Clean the moisture sensor contacts inside the
dryer and th
