I have cleared the filter, swept the inside of the filter with a fine brush, cleared the condenser unit and ran water through it several times. However the display only shows clean filter and it will not let me push any buttons or start a cycle- only beeps at me. Can anyone think of anything I can do here? Maybe reset the machine or any hidden sensors etc.?
SOURCE: Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
SOURCE: several cycles to dry clothes
rafbx in looking this complain over I got to thinking. You said the filter is clean. Have you tried running water over the filter to see if it will go thru? If not give that a try. Slow steady stream of water then put the filter under the water. It should go straight thru. If not then wash the filter with some detergent until the water goes straight thru. I have seen this before. Give it a try, you may be suprised.
SOURCE: Bosch condensation dryer model WTL5400vc. lint filter alarm
there is a reservoir in the base of the dryer which holds some condensing water prior to the pump pumping it to the holding tank at the top this has a float swith to tell the pump to come on and drain water to top tank this is probably stuck in the on position so the machine thinks it is always full of water and its waiting for you to empty it,you need to remove side panel and remove flost switch to clean, remove condenser and put youre hand in back of unit if its still very wet in there thats the problem should be bone dry at end of cycle.
hope this helps
SOURCE: our hotpoint ctd40 condenser dryer
I would get an electrician to check the machine as it appears to have an earth fault on the machine wiring , This type of fault will operate the RCD quicker than the fuse will operate. I am a qualified electrician by trade.
Hi
I
believe that everything else is fine rather it is the thermal fuse that is
located inside the rear panel to the exhaust duct that is bad and should be
replaced. If you want you can test this fuse for continuity and if it is bad
then it should be replaced, as it cannot be reset. If the fuse is fine then it
can be due to the control board that is bad and should be replaced.
Hope this helps...please post back for further assistance.
Daniel
