When plugged into my power strip (which gives off about 108V, low side I know, but all my systems work well) the voltage boost turns on, I wanted to know if there is anyway I can make the UPS think that 108 is fine so the Voltage boost would turn off?
SOURCE: SMART UPS APC 3000
let the ups be turned on just charging the batteries, u can have the voltage but the batteries still not fully charged. good luck
SOURCE: low battery alert on my apc - ups es350
Have your supply voltage and frequency checked under load.
/bz
SOURCE: APC ES-350 won't turn on; all I see is a blinking light.
Try looking for a small circuit breaker on the side that says "press to reset" - you could have tripped it accidentally when you unplugged the iPod. Also, try pressing and holding the UPS power switch for 10-15 seconds. That should force a power on as well.
SOURCE: APC external Backup battery is not working plz
Solution #1 is absolutly correct.......
But...keep something in mind. You also have a 50-50 chance that the inverter may have also gone...with the battery. So you could buy a new battery for $30.00 or you could by a new UPS for $65.00
So does this APC you have seem almost disposable?
The question is....if you buy a $30.00 battery and the unit does not work, then you buy a $65.00 UPS, how much did it actually cost you? Just consider that option.
www.storminprotection.com
SOURCE: When I turn UPS it starts to make a squealing
yes one side of the mosfet is faulty can be found by multimeter desolder and replace it
